1989 Renix Injector swap
DarkoShadow
Oregon
Currently have a mostly stock 1989 Cherokee, about 205,000 miles on it with AX15 behind it. Wanting to upgrade injectors to 4 hole. All research if found says to get part # 0280155703 - but with different flow rate? Would these work?
If I use Bosch 0280155703 :
Is it too much fuel?
Too high pressure rating?
Will the piston get hot spots that will eventually blow the rings?
Has anyone put these in an 89' ?
I search for upgraded injectors and find websites that say these are the ones I need, but when looking to buy, they say to use 710's instead.
Ok, think I found enough info to try this all out. I'll comment back once if installed an run a tank or 2.
I haven't done a swap but, most injectors are rated for a flow rate at a particular pressure. IIRC there are conversion charts for finding the flow rate at a given pressure. Hope that helps for your pressure rating question.
