gator_grabber
- Gainesville, FL
I've had an intermittent problem starting my Jeep after it has run for an hour or so. It will fire, run rough then die. If you give it a few minutes, it normally restarts without issues. The CPS is new and the fuel pump tests out fine. These are the readings that I'm getting from my TPS (1988 auto) with the throttle closed:
4.9 volts in
.67 volts out
This doesn't seem correct, but then again I'm running on a total lack of sleep. :speepin:
Any thoughts?? Thanks.
4.9 volts in
.67 volts out
