1986 mj
95blackbetty
Ohio
Hey everyone I'm sure this has been asked before but I'm looking at 86 mj with the 2.8 v6 the motor is junk and needs a new one after a little research I've found that 2.8 isn't a good motor at all so I was wondering what would be a good swap for it what kind car should I look for
Get a 3.4 v6 from a 93-95 camaro. Essentially It was the last version of the 2.8 gm made, bolts right up,
You'll need a balanced flywheel and electric fuel pump other than that just bolt on all the 2.8 accessories and go.
Or even get the whole camaro engine harness and wire that in , several write ups on it.
Next biggest favor you can do for yourself if you keep the carburetor is to upgrade that to a Webber and possibly the intake manifold and go with a four barrel Holley
Last upgrade would be exhaust manifold but I don't think there are any around anymore
But whatever you do the 3.4 is the way to go, it's a direct fit and a much improved design
X2 on the 3.4. It needs to be the rear wheel drive version. Font drive engine blocks are different. (No RH engine mount bosses for starters) I'd recommend an aftermarket two barrel manifold with a Holley two barrel. Although i've heard good things about the webber setup.
There used to be a 3.4 crate motor GM sold for S10 and camaro owners, sadly no longer available. You might find a used motor out of one of those but the best bet is the 93-95 camaro or firebird.
The 2.8 has a bad reputation, and I agree it's under powered, the edelbrock intake and new carburetor help out a lot.
Personally my 2.8 went through hell and never quit, I've heard other stories of the same longevity.
The Weber DGES 38 kit is a good choice if you keep the OEM intake. If you do get this kit keep in mind the adapter is designed for the s10 engine bay so the bolt used for threading to secure the air intake need be shortened for the jeep
Edelbrock intake # 3785
Edelbrock 3787
Adapter plate can be used with Weber carburetor and I suppose Holley and OEM
Edelbrock 3789
Is the adapter for the 4 barrel Holley carburetor 8007 390 cfm
A few XJers have used the 93-5 Camaro/firebird ecu, intake, injectors and wiring harness.
Basically a good 3.4 with nothing else done , besides for needed to adapt it, will be a good choice to get on the road again.
