Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Reaching close to 100 F at 75% humidity here I suspect.
There was a hot all the time line in the wiring layouts to an anti-diesel timer that operated after the engine turned off on a timer. I disconnected the two that where humming, but found another load on the running lights with ignition switch off and head lights off. WE had the dash pulled apart 4 months ago and ran some fresh wires through the dash then. If it was a time delay headlight deal, why are just the running lights on? Hmm, I do have an aftermarket harness running the head lights only. I wonder if that could be it? i.e. could be a head light delay timer issue? Never had an issue with it before, and the headlight switch power is a new line, hot all the time for 8 years, by passes the ignition switch
