12+ Axle building/modifying articles
Tim_MN
Freakish Hand Strength
Minneapolis, MN
I lifted these axle building/ modifying links from another forum I belong to.
Look for some ideas and check out what some other folks are doing.
http://77cj.littlekeylime.com/web_rs44.html
Dana 44 info plus some Dana 60 front and Semi float rear.
http://77cj.littlekeylime.com/flatop_knucles.html
Flatop knuckle info for Dana 44's
Other Links for a good read on axles:
My WICKED set of Steering Articles http://www.rightcoastcrawler.com/billaVista/Steering/Steering_Index/SteeringIndex.htm
Hybrid Dana30/Dana 44 axle, locking hubs, and high clearance steering. http://www.rightcoastcrawler.com/billaVista/Hybrid_Axle/HybridAxle.htm
Building a Reverse Rotation Front Dana 44 http://www.bc4x4.com/tech/2000/hpd44front/hpd44front.cfm
Building a Reverse Rotation Dana 60 for the rear http://www.bc4x4.com/tech/2000/highpiniond60rear/highpiniond60rear.cfm
Building a high pinion Dana 60 for the front of a CJ-7 http://www.bc4x4.com/tech/2001/hpd60front/
John Nutter-
From The Archives: Narrowing a Dana 44 Front Axle To Fit a CJ http://www.4x4wire.com/jeep/tech/axle/conv/dana44/fsj-cj/
C_J_Ford-
General Axle Information
http://cjford.stormloader.com/Tech/techstuff1.htm#Axle
Front Dana 44 axle for a CJ http://cjford.stormloader.com/Jeep/jeepaxle1.htm
Jeep Wrangler YJ Front Axle Swap - Reverse Cut Dana 44 http://www.4x4wire.com/jeep/tech/axle/yjrcdana44/
4x4Wire.com Product Review: CTM Racing Dana 44 U-Joints http://www.4x4wire.com/jeep/reviews/ctm02/
Dana 60 Manual http://www.solidaxle.net/dana60manual/
How to shorten a 78-79 axle. http://alxsbronco2.homestead.com/axles.html
Warns axle chart: http://www.warn.com/warn.nsf/pages/ContactUs.LiteratureRequest.Main.html/$file/warnhubaxle.pdf
Jeep Axle Swaps: Front Dana 44 http://www.jeeptech.com/convaxle/d44f.html
ABR's chart. Good-fair for Spline count. www.arb.com.au/alaclusa/215110.pdf
Everything you've ever wanted to know about Ford 9 Inch Differentials! http://66.96.130.106/archives/2002/02/nineinch/index.shtml
