POSJ
- Minot ND, Unfortunately
Disclaimer:
This will be my build thread and it is going to take a long time to complete(2-3 years) so don't expect a ton of updates. I have asked questions in modified and created multiple threads elsewhere but I am trying to bring it all to one section and I will give and follow up post bringing it up to speed eventually. The fab and engineering in this section will not be as advanced as some of these threads in this section that I have gotten some knowledge from but I will do my best to keep it "advanced"...that being said it will not be "hardcore" per Pirate4x4.com rules. I am learning and have no preconceived notation about knowing everything so if you have advice please let me know...So here we go:
As it sits now:
1991 Comanche
4.0L/AW4/NP231
D30 Front with 4.56 gears, ARB, Warn Hubs
D44 Rear with 4.56 gears and a Spool
Flatbed(hopefully get to keep it)
RAD Rail
Warn Winch
35x12.50-15 MT/R Kevlars
1991 Comanche Build Sheet(Hopefully)
Axles:
Front: -2005 F-350 Super Dana 60 $300
-Ballistic Dana 60 Shave Kit $265
http://www.ballisticfabrication.com/Dana-60-Shave-Kit_p_1848.html
-Yukon R5.38 Gears $271
https://www.ringpinion.com/b2c/ProductDetails.aspx?ProdID=3750&Source=DiffWizard&Show A=true
-Detroit Locker 35 spline $667
http://www.justdifferentials.com/category-s/3198.htm?searching=Y&sort=13&cat=3198&show=10&page=3
-Wheel Hub 2ea $375
http://www.rockauto.com/en/catalog/ford,2005,f-350+super+duty,6.0l+v8+diesel+turbocharged,1430817,brake/wheel+hub,wheel+hub,7632
-Brake Caliper and Bracket Left $77
http://www.rockauto.com/en/moreinfo.php?pk=6537996&cc=1430817&jsn=546&jsn=546
-Brake Caliper and Bracket Right $77
http://www.rockauto.com/en/moreinfo.php?pk=6537992&cc=1430817&jsn=547
Total: $2,300
Rear: -1998 Ford E-350 Dana 60 $300
-Ruffstuff Brake Kit $328
http://www.ruffstuffspecialties.com/catalog/R2054.html
-Yukon 5.38 Gears $282
https://www.ringpinion.com/b2c/ProductDetails.aspx?ProdID=12251&Source=DiffWizard&ShowAA=true
-Dana 60 Cover $125
http://www.ballisticfabrication.com/Dana-60-Differential-Cover-WELDED_p_1592.html
-Spindle Rebuild Kit ~$200
http://www.rockauto.com/en/catalog/ford,1999,e-350,7.3l+v8+diesel+turbocharged,1354496,brake/wheel+hub,wheel+bearing,1672
Total: $1,602
Suspension/Steering:
Front: -Ruffstuff or HDOffroad 3 link brackets/ends $632
http://www.ruffstuffspecialties.com/catalog/3LINKKT.html
-Shocks/Springs *To Be Determined*
-Hydro Assist steering(street legal) *pricing in future*
-GM TRE Steering $245
http://www.ruffstuffspecialties.com/catalog/XOGMSTE.html
Rear: -Leafspring +2 Perches $142
http://www.ruffstuffspecialties.com/catalog/2PLUS.html
Chassis/Body:
Frame: -HD Offroad Stiffeners/Ruffstuff Stiffeners
-2x6 .250 Box Stiffeners
-Minimal Exo Cage *TBD*
Wheels/Tires: -16/40-17 LTB’s
http://www.4wheelparts.com/Tires/16-40-17LT-LTB.aspx?t_c=13&t_s=536&t_pt=101509&t_pn=SSTLTB-203
-Black Steel Wheels $92ea
http://www.4wheelparts.com/Wheels/Series-98-Rock-Crawler-Gloss-Black-Monster-Mod-Wheel.aspx?t_c=11&t_s=535&t_pt=101508&t_pn=PCW98-7887
-Rear Axle Wheel adapters 8.65 to 8x170 $120
http://www.amazon.com/Billet-wheel-Adapters-126-15mm-14x1-50/dp/B00EKWM1WY/ref=sr_1_12?s=automotive&ie=UTF8&qid=1457468876&sr=1-12&keywords=8x6.5+to+8x170+wheel+adapters
As it sits now:
1991 Comanche
4.0L/AW4/NP231
RAD Rail
Warn Winch
Axles:
-Wheel Hub 2ea $375
Total: $2,300
-Dana 60 Cover $125
Total: $1,602
Chassis/Body:
