matt1994xj
- Houghton, MI
RyanM said:the new gear oils don't work with the AX brass syncros matt
so they dont make gl3 anymore? i havent had any trouble finding any. although i havent needed to in a while.
matt1994xj said:so they dont make gl3 anymore? i havent had any trouble finding any. although i havent needed to in a while.
RichP said:I maybe wrong but I don't think ATF lubricates, its more of a hydraulic fluid.
I'd hesitate to use it in a 2-stroke, because the correct oils are not only formulated to mix well, but also not to leave residues. Look around and you'll find that there are some 2-stroke oils out there that dye the gas either red or blue-green.Zuki-Ron said:Actually, it has excellent lubricating properties.
All the bearings in an automatic transmission are lubricated with it.
Transfer cases use it.
I even run the stuff in my chainsaw, weed wacker, and snow blower because it dies the gas Red so I can tell the difference. Same mix, 50:1
Ron
Matthew Currie said:I'd hesitate to use it in a 2-stroke, because the correct oils are not only formulated to mix well, but also not to leave residues. Look around and you'll find that there are some 2-stroke oils out there that dye the gas either red or blue-green.
I've not had a problem in the 10 years I've been using it. The engines actually run a bit cleaner than running the "2 Cycle oil" that they sell in little bottles.Matthew Currie said:I'd hesitate to use it in a 2-stroke, because the correct oils are not only formulated to mix well, but also not to leave residues. Look around and you'll find that there are some 2-stroke oils out there that dye the gas either red or blue-green.
huh? then why do they still keep selling the AX15 75-90 transmission lube ?Ten High said:as per chrysler, 10w30 is the proper "new" lube for the ax15. if you were to take it to the dealer that's what they'd put in.
RichP said:MT-90 for the tranny and Mobil-1 ATF for the transfer case.
