slapshot
- southern alberta
hey all.
just finished installing the 10 gauge wiring harness i created today, brutal in the cold weather here in alberta, but what the hay. thats a joke ps.
anyways. i followed fitchva's design/ wiring diagram for the harness, but think i messed up at installation. i had to jerry rig a new H4 female connection due to a size issue, during the rigging i'm almost certain one of the following things occured.
1- i mixed up the plug pattern so that the hi/ lo/ ground wires are not in the right place
or
2- initially i plugged the male H4 connection into the wrong sockets
i pluged in the passenger side etc, but left the driver side oem so that i could check out my handywork.
basically i suck.
when i turn on the lights, nothing happens, but when i pull back for the hi beams, they seem to work fine. then when i let the hi beams go the lo's come on. this sounds almost completely reverse to the issue everyone else seems to be having, with the stock fog lights etc etc.
also. when i tried to plug in the passenger side, with the vehicle off, the light goes on. pretty dangerous because of live wires etc etc.
so i've dosconnected my battery and am planning my attack for tomrrow.
i was wondering if anyone could help me decide whether i need to switch the connection at the oem harness, or on my harness at the bulb.
any help would be great and save me ooodles of tinkering.
also i dont have a voltmeter/ multimeter, so testing via that method is out.
feel free to ask for clarification if required.
much thanks
or
basically i suck.
much thanks
