1.25 WHEEL SPACERS
xjjeeper19
I have a set of 4 1.25 hub centric wheel spacers. I bought a set of 4, and only used two of them for about a month or so while I was wating for my soft 8's. I painted 2 of them black (the 2 that I used) the other 2 have never been used. only problem is that I robbed the lug nuts off them, so you will need 20 lug nuts for a 1/2 stud. These are spacers, not adapter, they will not change your lug pattern.
Asking $40.....I can ship them if needed for free to socal members.
Justin
3rd
KRAKER said:
Thanx for holding them I'll be in IE in about 2 hrs.
Hey, John the lug nuts that you'll need for those are a little different than the ones you'll find at your local auto parts store. They're an open ended nut with a wider seat (similar to the ones that came with the factory alloy wheels, just open on the end)........King Bolt, here in Covina has the ones you need....they're only $.45 a pc. I just picked up 20 of them for my wheel spacers (mine came with nuts more suitable for steel wheels)-------------Hans
