- bourbonnais IL
got a 02 WJ with the 4.0 in it, i figured i had the typical oil pressure sender problems. the gauge will drop to 0 and the check gauge light will come on give it some gas and the pressure will build. i swapped out the sender and it seemed fine i drove it for about 30 min before giving it back to the wife, everything was operating as it should good reading on the gauge and everything. well on her way home she said the pressure dropped and the light came on again. where else do i look? its got the typical 4.0 leaks but nothing serious and the is no oil squirting out from anything.
