01 Wj, 96 Xj, 00 XJ parts
H8PVMT
Central Maine
have no place to keep this crap and I'd like clean the back of my heep out so here it is, everything is BO
rebuilt 8.25 27(might be 29) spline drum to drum with brakes done at same time(4k on it) complete new e-brake installed 3.07 gears $125 obo
rebuilt engine (less than 30k on it, early 90's block, HO head) comes with everything that bolts on it 600 obo
teal hood off a 93 was in excellent condition when I saw it last 3 years ago $50
stock front bumper off red 00 sport $40
possibly 3.5" lift, no idea what brand but no sagging in over 4 years if interested shoot me an offer
96 Xj 5sp
distributor $30
side view mirrors $10
flywheel for ax-15 $40 (was machined recently)
starter with a few months on rebuild $30
power door locks, drivers side 2dr $10'
rear view mirror $5
2000 XJ
engine mounts OEM in near new condition $30 for pair
starter (needs a new bolt for wires) $25
Parts from a 2001 6cyl AT Grand Cherokee
TB with sensors $40
accesssories brackets $10 each
motor mounts $30 for pair
cam sensor $25
ac compressor $40
flywheel and flexplate $40
WJ Tranny lines in excellent condition $25
Alternator $30
Complete wiring harness $100
TC cover $15
5 31x10.5x15 BFG AT/KO's 2 new, 3 worn on AR rims $300
can ship on your dime and deliver the bigger stuff within reason
Thanks,
Doug
tell me about the engine
what is it?
what year?
who rebuilt it?
it was a jasper engine put into a car that got wrecked (in the back) 10k miles later, was running it in my 96, buddy painted the block red but in the spots that's fading you can still see the blue paint from jasper, block is from the early 90's judging from the knock sensor on it
high outputs used a knock sensor? i thought that was just renix.
but if it worked in the 96 i might be interested. idk yet lol.
4.0 i can only assume
no clue what year the head is, just that it's an HO, and yes 4.0 6cyl engine
tranny is your's don't worry, just posting what drivetrain was in it in case that makes a difference
guessing it's a skyjacker? (red paint on parts) lower arms, springs, leafs, look like fulls, can send you a picture, putting it in my new xj unless I get a good offer, using the "dirty" method it measured 3.5"
Do the side mirrors come with the mounting brackets that attach to the door?
only pass side left
Bump
Wj motor mounts, lift and tires gone
Everything else is best reasonable offer
it's from a manual, so if you have an automatic I don't think it would work
but it will fit cherokees from 91-2000
it will fit XJs 91-01 I think, I know it will fit 91-99. 6cyl only.
only manual though obviously, you need a flexplate for an auto. If you have an auto I have 2 spares I don't need, drop by and get one.
