Saltfisher
- Ephrata pa
Hey guys, i have a problem. I have a 2000 XJ. Was cruising on the highway and all of a sudden everything went to neutral. I thought my buddy hit the shifter in N, but he didn't. Finally engaged after playing with the shifter at a complete stop, but as soon as you start to go, it revvs a little, then catches and shifts 2 times pretty quick, and that's it. Top speed is 35mph and doesn't shift past that. I figured it was a tranny. I bought a good low miles tranny and put it in. Figured it would be fixed. It's still doing the same exact thing. Also reverse has a double clunk when put into gear, and I can hear a whine coming from the front. I replaced the TPS as heard it can cause tranny problems. No change... any ideas?? The garage I took it too didn't even have an idea.
This is the kicker.... during swapped trannys we checked codes with a obd2 scanner. Shows 2-3 solenoid circuit. Swapped tranny anyway, reset ecu and Same code shows up. Same exact problems. Almost like we never swapped the tranny. Both trans have thier own shift solenoid . I'm thinking something electrical?? Tried unplugging TCM under dash, and no difference. I'm at the point to give up and junk it. Need help. Thanks
