alek21
- Yorba Linda
here it goes...
d44 front out of a honcho, shortened and turned to cherokee length, custom 30spline currie axle shafts 5 on 5, wilwood rotors, calipers,and pads, currie spindles, warn lockout hubs, 4:56 ring and pinion but needs a carrier of some sort, warn diff cover, hi steer with 1.5 chromoly tie rod, drag link, and trac bar, they need the heims but already have the ends the heims require welded in, and a custom beefy trac bar mount, custom beefed up pitman arm. it hast he mounts for the wishbone tacked on but not fully welded in..
the wishbone and upper arms are made out of 1.75 chromoly, wishbone has the three fatty heims, and connects to the bottom of the axle as the lower control arm, all tacked together needs to be fully welded. custom crossmember that has a t-case skid with removable bottom plate for access to the t-case, made out of 1/4" stainless and is beefy as hell, can attach the wishbone and arms off of it, i have the mounts to be welded onto it they just arent welded on yet
im sure im forgetting things, theres a lot of parts and whatnot
askin 1500 for everything
thanks for lookin
thanks for lookin
