stumpXJ
- Atlanta, Georgia
Wasnt 100% sure where to put this, but figured it would hurt to go in here.
As any XJ owner knows, the lack of good drink holders in the XJ is a pain in the butt. I decided to make my own this morning, and just wanted to share. I am happy with the results, hopefully it gives ideas to others for a similar concept.
I used thin (about 1/16) anodized aluminum sheet for the main piece, and painted it semi flat black. I used anodized aluminum tubing for the lower shelf supports, and 1/4 thick delrin plate for the lower shelf. Mounted to the stock screwes on the center console, and also added two more on each side for weight support. I used stainless steel screws for the mounting and building duties. Its very lightweight solidly mounted.
Of course, no proper drink holder would be complete without speed holes:
I had to make it taper out so I could fit two holes side-by-side:
Mounted up, of course the e-brake can still be used:
Doing what its supposed to do:
~James
~James
