- 29°58'28.9"N 99°15'15.5"W
Yep, it's for sale.
2000 classic
Back is chopped
D & C cage
Waggy 44s
Spool in the rear, Detroit in the front
Alloy shafts front and rear
Dutchmans in the rear and Yukons in the front.
Front and rear discs
5-35" General MT tires
The frame rails have been boxed
The cage has been tied into the boxed frame rails
Reinforced and extended rear shackel boxes
Coustom made leaves in the rear by a local shop
Front has RE drop brackets, Adj control arms, Rock krawler 5 inch front springs.
Front and rear bumpers are home made.
I do not drive this everyday, I have driven it to work and back many times.
It drives on road very well but according to the mood of your local L.E.O. I would not plan on this being a D.D.
The motor, trans, and Xfer case has only 53,000 miles.
The axles have less than 1000 miles on them since rebuild with alll new parts.
The body is rough and the rear doors do not open.
But if you want a turn key rig, this it!
I am thinking $6000.00 for this.
2000 classic
Back is chopped
D & C cage
Waggy 44s
