Old December 9th, 2007, 16:33
indy_xj indy_xj is offline
0331 head change results
hello all. I got my 0331 membership card validated about 2 months ago. Its a 2000 XJ Classic with 53,xxx on the clock. The usual symptoms, Started with a temperature jump one afternon. It didnt overheat, but the needle was leaning further right than i would have liked. This was followed by unexplained coolant loss. Oil never got 'milkshake' and my oil volume was always full, never over-full on the dipstick. I think my leak was mostly being consumed in exhaust. Confirmed the leak by pulling the valve cover. I could definitely see coolant residue on the top of the head.
I relpaced the 0331 head with a 630 head with a 1998 production date. I ordered a new exhaust header. The 'accordian' one that i have seen a couple of other guys here use.
Change was very easy, sorry no pics . I am an average DIY guy. It took about 10 hours. I went slow, and took my time to make sure everything was good. Worst part is scraping/cleaning the top of the block and torquing the head bolts.
I was looking for the following info while researching what head to replace with. I post my results here for others benefit.
1. the '00-'01 intake fits the 630 head fine
2. the '00-'01 exhaust will not fit
3. you need an intake/exhaust manifold gasket for a '96-'99
4. you need an exhaust header for a '96-'99
5. valve cover and gasket are same
6. head gasket is the same
7. there are no bosses for the coil rail bolts. make a bracket like others have done.
8. need a new down pipe from the header to the rest of the exhaust.
9. i used new head bolts for piece of mind (FSM says re-using once is ok)
I have one question. I got all of the head bolts torqued to spec, per the FSM. It has quite a torque, check sequence. Do i need to re-check torque in 50, 100, 200 miles? The FSM doesnt say to so i think i am ok.
hope this info is helpful to any others that join the club.
late,
ixj
Old December 9th, 2007, 16:39
nick86's Avatar
nick86 nick86 is offline
Re: 0331 head change results
No need to re-check torque on the head bolts, you'll be fine.
Old December 9th, 2007, 16:42
darjevon's Avatar
darjevon darjevon is offline
Hey,
Great job!
The torque doesn't need to be rechecked as the 4.0 is a low compression engine, provided you are sure you set them right the first time.
Joe
rstarch345 rstarch345 is offline
If you torqued your head to FSM specs, you shouldn't need to recheck.
I know it's after the fact, but a Banks header for a '00 and up covers the exhaust ports just fine on a 0630 head. I'd already changed the header prior the head crapping out on mine.
If the exhaust header you used was SS, you'll want to go back and check the torque on them around 500 miles.
Old December 9th, 2007, 17:04
5-90's Avatar
5-90 5-90 is offline
No need to recheck - new head gaskets are made better than they were before...
I do have a question tho - since you were using (I presume) OEM parts, do you have a description - or better, a picture - of the interference between the manifolds as you tried to use them? Was it a clearance issue, or a port size issue? Where the screw holes in the wrong place?
Just wondering - I'm always trying to update my notebook on things like this...
Old December 9th, 2007, 17:27
5-90,
Correct, all OEM parts.
A couple of the ports would have been ok and a couple of the ports would have had some gaps
The exhaust ports on the '00+ are a fair bit smaller than the < '99.
The '00 header has square ports and the < '99 gasket has round.
The '00 gasket wouldnt line up with the 0630 exhaust ports either.
A < '99 gasket with '00 headers might have held for a while, but probably would have developed a leak. And that certianly wasnt worth it.
sorry i dont have any pictures. If you go to your favorite online parts database and look for an intake/exh gasket you can see the diff on a 2000 vs. 1998.
or google for
felpro ms94790 (1998)
felpro MS93094 (2000)
These look just like the OEM stuff.
I have federal emissions, so only 2 O2 sensor (1 pre, 1 post). The guys with cali have more O2 sensors and that would cause more problems with the exhaust.
regards,
ixj
Old December 9th, 2007, 17:55
XJ01-08's Avatar
XJ01-08 XJ01-08 is offline
yeah im dealing with a check engine light from taking off the precats anybody now where to get some good O2 simulators
Old December 9th, 2007, 19:56
5-90's Avatar
Makes some sense - I know the exhaust ports were reduced in size for the 0331 casting, to "improve catalyst light-off" (keep gasses hotter until they get to the cat, and get the cat up to op-temp faster.) Still, it would seem that making the ports smaller into the larger tubes should not cause any significant trouble - I didn't think they'd moved them as well. I'll have to dig into that a little more.
For the downstream HEGO simulator, check pretty much any speed shop, like Jeg's or Summit Racing.
Old December 10th, 2007, 01:42
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
Pics of your coil rail bracket(s)?
Old December 10th, 2007, 07:56
i dont have them totaly finished. Hopefully in the next day or two i will. When they're done i'll post some pics.
ixj
Old December 10th, 2007, 08:14
kahaikapu's Avatar
kahaikapu kahaikapu is offline
Unhappy Re: 0331 head change results
If the o331 head is a known problem..why isnt Dam/Crysler helping out in warranting those bad heads?..Aloha Stan
Old December 10th, 2007, 08:36
These cars only carried a 3 yr/36,000 mi warranty, not the newer 7/70 or newest lifetime powertrain. By the time the first bunches started cracking they were out of warranty.
Also:
- D/C might have 'fixed' the problem by late 2002, early 2003. There are very few, if any, reports of 2003-2005 TJs having the problem. There is some disagreement on this
- Its not saftey related, so they arent forced into a recall situation
- The affected models ('00 & '01) are now 7 and 8 years old. D/C is letting this one fade off into a memory.
ixj
Old December 10th, 2007, 09:02
StylerG's Avatar
StylerG StylerG is offline
5-90
i just did this swap with a complete engine, but am still dealing with the exhausxt, i might be able to get you some pictures side by side of the difference in the exhaust manifolds (its suprising!!!)
heck give me a couple of weeks i might ship you both of them on your dime so you can compare yourself ha!
Old December 10th, 2007, 09:16
Devilfrog Devilfrog is offline
I picked up both the '00 and 91-98 Felpro gaskets ... the '00 matches fine in the intake side but not the exhaust, and trying to use the stock manifold with the earlier gasket won't work as the 91-98 gaskets exhaust port seals are wider that the entire cast manifold (as in there are spots where the manifold outside edge would be inside the earlier port seals).
Old December 10th, 2007, 10:57
5-90's Avatar
One other question (for anyone who may be reading this) - how can one tell the "original" 0331 cylinder head from the "revised" casting, that corrects the cracking issue? I've yet to sort that out, and I've been asked a couple of times...
NY: 0331 HEAD (CRACKED) mtsz52784 FREE Items. No SPAM 0 May 12th, 2007 10:15
0331 head replacement Ben H For Sale: Private Party Only. XJ ITEMS ONLY 2 January 25th, 2007 16:38
0331 head [low emission] Dmanti OEM Tech Discussion 4 January 9th, 2007 17:48
0331 cylinder head questions caz OEM Tech Discussion 2 December 22nd, 2006 17:48
0331 head Identifing dyna OEM Tech Discussion 6 July 28th, 2006 17:47
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
