How can you tell if your a/c condensor is working? Do you hear a switch go on when you turn on the ac? I'm getting regular temp air blowing with the a/c on. Not sure if it's the refrigerant though, it's probably all gone. how could i check for those things?
Also how can you check that coolant temp sensor and o2 sensors are still good? what reading should you get on the ohms meter for those two.
it's a '93 XJ with 99k miles
