OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Seat cushion foam
Okay. Been trying to find a part number for this for a few days, and am having zero luck. Hopefully someone with access to a Chrysler parts catalogue can lend a hand.
I need new seat cushion foam (both in the squab and seat back) for the driver's side on my 2000 Limited. Evidently the previous owner was heavier than I, and it's shot. This wouldn't be such a big deal, but I'm starting to develop back pain after even relatively short drives (+/- 2 hrs.) in the Jeep. It has the six-way power leather seats, if this makes a difference. If I could also get the numbers for the passenger side, it'd be a bonus. Unfortunately the best luck I've had so far recommends replacing the entire seat - and at $650, that's right out. If there's no OEM part number available, if anyone's aware of an aftermarket source it'd be much appreciated. |
#2
Re: Seat cushion foam
i don't mean to not be any help by saying search, but i recently saw on some site a write up on how to restuff the front seats. if i come across it again and remember where it was, i'll send it to you, but hopefully someone else has it stickied or knows which site it is hosted on. i'm sure they'll either mention a part number or simply tell what product they used and where they got it.
#3
![]() Quote:
#4
#5
casm, another trick to try. Is replacing yours with seats from a ZJ, or WJ. Should be farly easy to find a set, and they ae supposed to bolt to the XJ seat brackets. It is said they are more confey than there XJ counterparts. However I always thought the leather seats in my XJ where more confortble than the non leather ones in my ex's ZJ. Though it could just be the fact mine go back about an 1" 1/2 farther for more leg room.
Thread Tools | |
Display Modes | |
Front seat cover & cushion swap | gba88 | OEM Tech Discussion | 11 | October 8th, 2021 14:43 |
Transfer case mount/bushing/cushion | Rasputin | OEM Tech Discussion | 1 | February 18th, 2005 07:57 |
Seat foam gone mad? | BIGSLVRXJ | OEM Tech Discussion | 2 | June 21st, 2004 03:40 |
sea foam? | BPB | OEM Tech Discussion | 18 | May 18th, 2004 08:54 |
Sea Foam? | Kevin | OEM Tech Discussion | 2 | March 25th, 2004 06:23 |
