How to remove center console, dash bezel?
it aint easy... take off the radio bezel, the shifter knob, the shifter bezel, the 4wd drive bezel.. remove two screws from that area, remove 2 screws (i think) from bottom of the console cubby thingy... pull 4wd lever all the back to 4 lo, put the shifter in about d, or 3 ... yank up on the e brake as far as itll go and see how you do, usually I have to play with the e-brake to get it to clear
the trim that goes around the radio & heater controls just pops out with 6 clips I believe...
yank up on the knob, pops right off.. bezel- pull shifter down some and pull from the bottom of the bezel, its just attached with clips so dont worry you wond break it, even though it might feel like it, but yank out the bottom and then get the top
