95 ZJ Power Windows Not Working
2Grim4U
East Tennessee
I have changed all fuses and relays, I have also swapped out the door harness as the old one had broken wires. None of the windows work at any door. Any ideas? Thanks
I had a similar problem. My passenger side window and mirror weren't working. Turns out it was the control module in the driver's door. It functions as a serial data interface for both windows and mirrors.
Turn ignition on and check voltage at the 30 amp circuit breaker (26) in the fuseblock. The should be voltage. If not, replace breaker (wiggle ...
There are two common causes for a busted power window in your Jeep: a worn out window motor, or wiring issues. The motor is exactly what it sounds like, as it controls the up and down movement human benchmark of the window, and sometimes, they just flat out die of old age.You can tell if the window switch is the problem if you hear the power window motor run, but the window glass doesn't move. You can press the switch in the other direction to confirm this problem. If the window moves, the switch might be to blame for the window failure
