Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old September 18th, 2019, 19:53
RCP Phx RCP Phx is offline
Scorpion roller rockers
I have a set of Harland Sharp's right now but looking for another set. Has anybody heard, seen, or used these, they are a little cheaper than HS's but have a interesting girdle/trunnion. They are available in adjustable also.
https://www.summitracing.com/parts/scc-0502/overview/
http://nebula.wsimg.com/0fd2f2a4fac68ed61c54832d17dfb9ca?AccessKeyId=38E82 0A0988CF20930C9&disposition=0&alloworigin=1
Old September 20th, 2019, 08:16
Re: Scorpion roller rockers
I dropped the coin on the Scorpion rockers, I don't mind being a "test pilot" and could always p/u some HS's later. Looking forward to seeing them up close and their girdle/trunnion set-up makes it easy to remove/install one rocker at a time vs both together. I don't know if they will work with my studs but will find out!
Old September 20th, 2019, 10:27
I'm going out on a limb here but I found and purchased (in 5/16-24) some Isky Poly-Locks and that should work for sure.
Old September 20th, 2019, 20:05
Groot99 Groot99 is offline
These have a better ratio for move valve movement?
I just saw someone post on Facebook about them.
Old September 21st, 2019, 07:05
Yes, my current Harland Sharp's are 1.6 (same as stock) and the new Scorpion's are 1.7's .
Old September 21st, 2019, 14:53
I received my rockers and polylocks. The rockers look well built but I can't use the polylocks unless I machine a good 1/4" off them and they are hardened steel.
Old September 24th, 2019, 09:40
Despite my concerns I ordered a Crown Aluminum valve cover in a attempt to use my polylocks. I will receive my adjustable push-rod tomorrow and I will start the project after that. I won't know how long it is going to take to get push-rods made, it will depend on the length.
Old September 24th, 2019, 14:20
techno1154's Avatar
techno1154 techno1154 is offline
Won't the adjustable rockers have saved you a step or two?
I used to enjoy adjusting the big block Chevy solid lifter engines.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old September 24th, 2019, 14:45
If I had bought adjustable's I would definitely have to do something with the valve cover.
Old September 24th, 2019, 16:23
I could have bolted the new rockers straight in, but when I built my stroker I had to shim the rockers up because of block/head deck cuts(already had the Harland's). I can't even guarantee what's going to happen now until I bolt them up and check the "contact patch".
Old September 26th, 2019, 19:25
I got my measurements done today, came up with 9.555". Add .040" for pre-load thats 9.595" so I ordered some off the shelf 9.600" 3/8" x .080" wall chromoly ones. I will look at the polylocks tomorrow.
Old September 27th, 2019, 11:01
Today I'm waiting on the valve cover to arrive. In the mean time I have been getting them all mocked up, don't know yet when I'll receive the push-rods.
Old September 28th, 2019, 10:24
techno1154's Avatar
I am accustom to the color of the Harland Sharp rockers. Those Scorpion ones look as if they are painted white,...different, but I like the looks of them. It will be interesting to see how they perform compared to the 1.6 ratio installed before.
Patrick
#594
Old September 28th, 2019, 11:06
The rockers are bare aluminum. I can't wait to see also, if I was at 300hp before! Today I'm am fitting the RT valve cover, they claim it has additional height but with the baffles in there it's going to be "close"
Old September 28th, 2019, 14:50
Down under Down under is offline
Sweet!
Rate This Thread:
Roller rockers for the 4.0 lonecountryboy Modified Tech Discussion 18 March 26th, 2009 07:49
Roller rockers for 319? PurpleCherokee Jeep Street and Performance 12 March 15th, 2008 14:09
roller rockers killer98xjsport Modified Tech Discussion 12 July 10th, 2007 22:27
roller rockers? Justpunchit Modified Tech Discussion 16 March 13th, 2006 03:23
roller rockers Sephrion Jeep Street and Performance 22 October 1st, 2004 23:27
