Old July 8th, 2016, 08:38
RCP Phx RCP Phx is online now
How did I end up with DLR's?
I just installed some LED headlights, high and low beam work fine but I can't figure out how those can operate as DLR's?
Old July 8th, 2016, 08:55
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: How did I end up with DLR's?
DRL's?
I've had trouble with most LED headlights as they somehow back feed through the fog lamp circuit.
Old July 8th, 2016, 09:21
Sidewinder CC's Avatar
Sidewinder CC Sidewinder CC is offline
Why do you want/need DLR's?
Old July 8th, 2016, 09:22
Yes, I meant DRL's! I love the lights right now, so we'll see. I needed to replace my 10 yr old Sylvania Halogens!
I didn't need DRL's, I just want to know how their operating? It's just a 3 wire sealed beam?
They don't come with the ign switch, but only when you start the engine!
Old July 8th, 2016, 10:23
Ou2mame Ou2mame is offline
Oh you mean they are on when the jeep is off? If that's the case, it's because they need such little power to operate and there is always a very low current going through the wiring. There are resistors you can install to eat that power instead of feeding into the led.
Sent from my SHIELD Tablet using Tapatalk
Old July 8th, 2016, 11:03
xCWolf's Avatar
xCWolf xCWolf is offline
Bring the Boom
I believe if you use something like a 6v zener diode if the voltage is under 6v it will block all voltage until it goes over 6v (like when you turn the lights on) than it will work as normal
Old July 19th, 2016, 15:40
Still myphed at how this works, but the headlights are fantastic!
Old July 19th, 2016, 15:46
5.9longarmXJ's Avatar
5.9longarmXJ 5.9longarmXJ is offline
My DRL killed my ballasts in a hurry. I ended up pulling the DRL module. Rather not have DRL and have the better headlamps.
Old July 19th, 2016, 19:11
There is no ballast! And it's a sealed led housing!
