Xj suspension bolt list
Wanderingwest1979
Alberta
Hi all, I'm new here, been a creeper for awhile. Thought I'd contribute something for my first post.
I'm not new to jeeps, I own 3 of them, and have owned 7 in total.
I am in the middle of installing and Old man emu lift on my 99 sport. I chose to replace all the control arm bushings in the process. Before all my parts got here I decided to round up all new fasteners as from past experience I knew some bolts would break or have to be cut out.
I could not find everything I was looking for in one place on line. And some posts led me to buying the wrong bolts.
So I decided to compile my own list here, and share it with you folks.
The bolts I used were standard bolts, no flange heads so I added a washer to either side. I have included nuts for the bar pin side of the shocks as like most, mine broke and I needed to fish new ones through the unibody. Some of these bolts may be a little shorter then factory, but unlike the factory bolts, these were cold rolled threads and they didn't go all the way down the bolt.
I have confirmed each and every one of these.
ALL HARDWARE IS GRADE 10.9! I have been told 10.9 is stronger then grade 8, feel free to correct me if I am wrong.
4- Upper control arms- M10x1.5x80mm (4 nuts required)
4- Lower Control arms- M14x2.0x120mm (4 nuts required)
4- Leaf springs/ shackles- M14x2.0x110mm (2 nuts required at shackle, frame side eye is welded nut)
4- Front sway bar at frame- M10x1.5x30mm
16- Shocks at bar pins- M8x1.25x35mm (with nuts, 4x lock washers if your rear bolts break and you have to go fishing)
1- Track bar bolt- M10x1.5x70mm (try to reuse factory nut)
2- Front sway bar end link stud at axle- M12x1.75 nuts
2- lower shock stud at rear axle- M12x1.75 nuts
2- front spring retainer- M8x1.25x25mm
Remember, factory bolts are flange head nipple tipped. If you aren't getting flanged heads, you will need washers, 2 per bolt.
I would highly recommend giving the Jeep a PB bath beforehand. Take note, for the frame side leaf eye bolts, you can get to the captured nut welded to the frame via a small hole in the frame just behind it. If you have a trailer hitch, the rear shackle bolts at the leafs will have to be cut out unless you want to remove the hitch.
Also, I would suggest you get yourself a good metric tap and die kit to chase any threads that you cannot replace like the sway bar mounts and the front leaf spring eyes. Last thing you want is used dirty threads making an impact on your torque settings.
Replacing control arm bushings was easy, a ball peen hammer and a block of wood is all that is required to remove and install (Google that), or ask me and I can post a video. Everyone said not to do more then one control arm at a time, but I don't listen and managed just fine. A 2-3" wide ratchet strap 10' long and slings made short work of pulling the axle into place.
Cheers!
Fantastic first post! :thumbup:
Did you replace the axle side UCA bushings? I'd like to see a video of your ball peen hammer and block of wood method with those.
Welcome to the forum.
UCA hardware is different for the axle and body ends. I forgot to write down the lengths, sorry! I used some WJ bolts from the junkyard, they are perfect.
Control arm and leaf bolts also have a shoulder at the flange end, to help with centering the bushing.
I've been compiling a list of the required bolts for the XJ suspension, but it looks like you finished before I did. :) Where did you buy the various bolts? I've found just about everything I need at Fastenal all the bolts added up to almost $100. I'd like to see your lift when you are finished as I am also lifting my 96 XJ using old man emu components. Thanks
ETA:
10.9 metric is stronger than metric 8.8 but equivalent to SAE grade 8
ETA:
I bought them locally in Calgary here at a company called Quest Industrial. With a tube of blue loctite, bottle of loctite clean n prep, it came to less then $75 Canadian.
It probably cost less then $75 as I have a pile of leftovers, and when I wrote the original list I just added 2 washers and 1 nut for every bolt, not all bolts needed them and for all the M8 and M10 stuff I got flanged nuts. I also originally had four M14x130mm and four M10x95mm for the control arms but they ended up being too long. I didn't bother to return them.
The sweet part was I emailed them at noon, and by 1:30 my order was ready.
This is what I got, everything individually labelled in little ziplock bags.
I ended up getting my local jeep club members a 10% discount too.
