Justpunchit
NAXJA Member #1291
- Jaffrey, NH
I don't have to sell these, if I don't get what I want for um they can always go into my other rig. but here they are...
We'll start with front...
Non disco hpD30 4:56's Aussie locker with fresh 297X shafts, fabricated shock mounts, welded tubes, and reinforced pass UCA bracket, and LCA skids, with new UCA bushings, and 3 year old balljoints. This also comes with a crossover heim steering setup complete with pitman arm and and a set of standard knuckles incase you don't want the heim steering, also has a warn diff cover for protection. Wheel bearings are in ok shape and Calipers are less then a year old. I'd say the whole rebuilt axle has maybe 15K miles tops. well over 1,000 into this axle.
$700/BO
Chrysler 27 spline with High clearence shock mounts shaved bottom diff and diff gaurd, 4.56's and welded rear. Comes complete with disk brakes and Yukon Alloy shafts along with the non alloy spares. Less than 10k on all bearings and seals!
$500/BO
These axles are complete from calipers to lug nuts.
$700/BO
$500/BO
