american_zero
- San Jose, CA
I have been lifted for a little while now and have run a few trails, but I finally got my disconnects on and took a trip to Hollister Hills (wasn't disco'ing before now). Got it flexed out and it does pretty well IMO. This is on 30" tires. I don't do any hard core rock crawling, just the occassional trail, but I found that I needed just a little more clearance under the Jeep to be comfortable. This has worked great as a budget lift.
The setup gave a pretty even 3" lift.
Front Springs: Moog CC784 springs (HD Grand Cherokee springs) with a second stock rubber isolator.
Rear Springs: ProComp leaf packs. 53111 is the part number I believe. I removed the overload leaf before installing to try and keep the ride liveable. Seems to have worked.
Shocks: The Monroes that are listed on Rock Lizard's website for their BB. Used the JKS BPE's in the rear.
Did not alter the bump stop in the front as the shocks were only 1/16" longer than stock, when compressed. Added 1" to the rear bump stop.
Used a 1996 Dakota (I think it was '96) rear brake line. Way long, but works just fine. Also, did not have to alter the front brake lines and they seem to have enough slack to be ok.
And JKS quicker disconnects in the front and I removed the rear sway bar. As much as I read about the rear sway bar not being needed, I was still expecting more of a difference when I removed it. I drive the Jeep pretty quick around on ramps and corners and I really don't miss it at all.
I think that's about covers it. It rides pretty decent and can handle being loaded down. I have had 5 people, 1 dog, tools, spare tied to the roof, and an ice chest in it while doing a light trail and it was fine. Loaded with gear, the rear end actually rides better.
I basically started reading threads here and looking at all the links people posted to different websites and write-ups and was able to cobble together the lift and install it without any prior 4x4 knowledge or experience. Now I just need to learn how to drive the thing. :roll:
