Old June 6th, 2020, 20:26
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Rear end bastard pack rebuild? FML
Front end shenanigans aside... Im on to the rear.
Ford 9, unknown lift 35s 4.57 Detroit locked center section. What started out as as a simple axle shaft seal replacement has mutated into full rear end overhaul...
New seals and axle bearings of course.
New pinion seal? sure
New emergency brake shoes?? Fiiiine
New U bolts and swap a leaf??!? WTF?!
Ya... my second leaf down is cracked and or broke on both sides. Can I add a leaf via the junk yard or elsewhere to fix this?? Do I need a full leaf pack? Does axle not matter, just where it bolts to the body?
This needs to be a hands on CHEAP fix... I already know U bolts are forked full rear end is getting pulled stripped and painted..
Any advice would be cool.. thanks yall
97 XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old June 6th, 2020, 20:27
Re: Rear end bastard pack rebuild? FML
Old June 6th, 2020, 20:28
Old June 6th, 2020, 21:22
RCP Phx RCP Phx is offline
You could replace a single leaf but you would need to know who built the pack in the first place to be able to match it.
Old June 6th, 2020, 21:58
ljobbins ljobbins is offline
I’ve had a broken leaf replaced by a leaf spring shop in Mexico and they just found a leaf the same thickness and width and length and used a press to shape and curve it to fit and give the same lift height. This is not ideal and does change the flex characteristics of the pack but it was a cheap and super fast fix to get me going. I trust it to drive around normally for a long time, but I would get a new spring or full pack before serious flexing or off-roading.
Old June 7th, 2020, 06:38
smokeyyank's Avatar
smokeyyank smokeyyank is offline
Jeepoholic
Bummer, just say f it and get some cheby 63s in there...
Kidding aside bastard packs aren't too expensive.
88 MJ truggy, 4.0HOybrid AX15, NP242 **Being built**
Mods: D44 w/ 4.30's, ARB front and Auburn rear, 33's
04 WJ, 4.7HO
Mods; 3" IRO lift, ADDCO rear sway bar, 4.7HO with bored fastman TB, AFE intake and Superchip tuner, 32s, lunchbox rear 242HD, 3" Kolak exhaust
Old June 7th, 2020, 06:54
SlowXj SlowXj is offline
Just get a leaf the same width and shine in there... Cut it so it's the proper length to keep the progressive nature of a lead spring. Think of an aal. Yeah they're not great, but they don't "match" the existing pack. Don't over complicate it and you'll be fine.
Old June 7th, 2020, 10:45
Ya, the original pack is unknown..
As much as I’d like some deavers, that ain’t in the cards as of right now.
I would probably be best served to swap the whole packs on both sides... I don’t want to do a temp job and have to tear it apart again shortly.
Axle isn’t really important, I’d just need correct length of springs?
S10 makes a good donor?
Are there any decent aftermarket packs I can go with? Or should I just replace the 2 with junkyard findings that are correct dimensions?
Old June 7th, 2020, 13:12
Like is this a bad idea?
https://realtruck.com/p/pro-comp-lea...cherokee/1997/
Old June 7th, 2020, 13:44
JonnyCat63 JonnyCat63 is offline
I would guess, and it's only a guess, that those are re-branded Rubicon Express springs, or very similar. Transamerican Parts owns Pro-Comp and RE.
I had a set of Pro Comp leafs front and rear on a CJ. IIRC they looked real similar to the RE's I have run. Not a bad spring, but not great either, IMO.
At 3.5", I prefer these:
https://www.ironrockoffroad.com/prod...f-springs.html
Old June 7th, 2020, 14:45
waxer's Avatar
waxer waxer is offline
Time for some Deavers!!!
92 XJ - Too much crap installed to mention!!
N1WAX
Old June 7th, 2020, 17:17
Ya man that’d be cool... but for $1k I’d be debating 4 link vs deaver. At any rate As I posted earlier in this same thread, Deavers are not in the cards atm.. if you want to contribute I will gladly PM my PayPal info tho!!
But ya know his is a junk yard fix or cheap arse replacement fix... I’d prefer to replace the whole pack as the origins of what’s on there is unknown. One already broke, so I’m not confident in the remaining leaves
Old June 7th, 2020, 17:29
Well, Id assume my lift is higher... but know the mount on the axle as well as shackles can play a part in that lift. Still trying to find a stock XJ in my neighborhood to take a tape to... Id guess 3.5 to be the number in conjunction with the rest of the set up.
Now with that said... I come from the ZJ world, where Rubicon Express always reigned supreme tbh. For coils shocks track bars and adjustable arms... you could not go wrong with RE. If we are now comparing RE to pro comp, Id say the brand has regressed big time. RE shocks were said to be bilstein rebrands or close. OME and RE were the shock of choice by far.
So at first I got excited to hear that those cheapos might be REs... now idk...
I do REALLY like every interaction and purchase Ive had with IRO though... including many parts on this very XJ.
Thanks for the recommendation
Old June 7th, 2020, 18:24
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
IRO is awesome customer service,ive had good experiences.
I dont know much about leafs, but if one leaf in a pack cracked, wouldnt that suggest the health of the leafs in general. Idk but my first thought seeing that picture would have me looking at new leafs or coils....
btw did you say deavers are 1000$? thats crazy coin lol, ill scracth that off a list if i ever replace leafs again.
im curious, but if you welded that as some type of temporary repair, would it work or just crack in the same spot?
Old June 8th, 2020, 08:26
899$ is going rate for Deavers... add tax and shipping. Might find a deal under $1k to the door, but just barely if so.
Ya welding isn’t a route I’d go on a suspension piece.. and to your point with the broken leaf the others in the pack have been working over old to make up for it I’d guess.. so ya replacing the whole packs seems to be the way to go.
Leaning IRO, I too have had nothing but good experiences with them
Do you have to do a bastard pack for the rear??? 01classicxj Modified Tech Discussion 11 October 7th, 2014 08:56
bastard pack rear springs jeeptec Modified Tech Discussion 12 September 8th, 2014 21:14
YJ Bastard Pack for rear of '97 XJ? ybstuk Modified Tech Discussion 3 June 7th, 2011 14:03
Bastard Pack Questions 1) wrench/socket size for leaf bolts 2) Use the bastard on 8.8 1988 Cherokoo Modified Tech Discussion 2 February 20th, 2010 01:38
rear leaf mj bastard pack... Red October Modified Tech Discussion 1 April 27th, 2006 22:08
