1988 Jeep Cherokee CHEAP to Good Home
JKooshTJ
Maiden, NC
1988 Jeep Cherokee XJ Pioneer Worksheet
Year: 1988
Model: Cherokee
Color: Black
Mileage: 168,896
Engine: 4.0L I-6 OHV Fuel injected
Clutch Diameter: 10.5”
Transmission: Auto (Aisin Warner 30-40LE 4-speed automatic)
Transmission Ratios: 1) 2.80, 2) 1.55, 3) 1.00, 4) .75, R) 3.55
Transfer Case: 2-speed, NP-242 full-time (a.k.a. NV-231J or NP-231J)
Axles: Front: FF Dana 30, Rear: SF Dana 35
Axle Ratio: 3.55
Overall crawl ratio: 2.80 x 3.55 x 2.72= 27.04:1
Doors: 2
4WD/2WD: 4
Package: Pioneer
Power options: N/A
Towing Pkg.: Factory installed
Wheelbase: 101.4”
Fuel Capacity: 20.3 gallons - Avg. 15.5mpg
VIN: 1JCMR7725JT148716
Owner’s Name: Heath
Power steering: Yes
Extras: 3” lift, 31” Super Swampers 25% tred left, front tow hooks, chrome front bull bar w/2 off-road lights, manual sunroof, rear tint, tilt steering column, towing package, rear seat, Herculined (like Rhino Linings bed coating), center console, new inspection sticker as of 9/2004, rims cleaned of black spray paint and shined, floorboards fiberglassed, factory roof rack
New Parts Installed: sway bars with disconnects installed up front, front wiper cowl, 2/0 guage battery cables installed for more power and brighter headlamps, horn and button, new rear taillight (passenger side), new rear hatch handle, new steering column and signal shifter, new clock, new rear u-joint, vacuum canister for AC/vent/heat usage, new oxygen sensor, interior courtesy floor lamps, rearview mirror
Faults: (These are figured into the price already) power steering leak, slight main seal leak, part time 4x4 light stays on (4x4 works flawlessly), passenger side door needs adjustment ( but closes just fine), no radio, no speakers, no antenna, possible alignment needed, front seats do not fold forward, AC system needs conversion and recharge, front and rear wiper motors need replacement, no headliner, drivers side brake bleeder screw needs replacement
engine compartment fuel leaks (o-rings, pipe entry to vacuum can on fuel rail THIS IS THE MAIN PROBLEM & I"M TIRED OF TRYING TO FIX IT :rattle:
Asking Price: $800 asking price
Important Service Dates
Oil Change: Sunday, May 23, 2004 (mileage 164720) Change every 3000 miles. Next change at (167720)
Oil Filter: Sunday, May 23, 2004 (mileage 164720) Change every 3000 miles. Next change at (167720)
Transmission Fluid: Sunday, May 23, 2004 (167720) Change every 15,000 miles. Next change at (182720)
Transmission Filter: Sunday, May 23, 2004 (167720) Change every 15,000 miles. Next change at (182720)
Fuel Filter: Sunday, May 23, 2004 (167720) Change every 30,000 miles. Next change at (197720)
Brake Fluid: Sunday, May 23, 2004
Transfer Case Fluid:
Power Steering Fluid:
Differential Fluids: Both differentials changed on Thursday, June 03, 2004 (Change every 3,000 miles.)
Air Filter: K&N Rechargeable Cone filter
Grease Points: Front steering linkage greased on Thursday, June 03, 2004 (Grease every 7,500 miles.)
Rear Brakes: Sunday, September 5, 2004 (changed brakes, NOT hardware)
Front Brakes: cleaned and serviced but not changed (no need)
Alignment: Never
** If you'd like some pictures emailed to you, just send me your email address and I'll ablige. **
Email me at [email protected]
