OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
I vote lie
https://www.foxnews.com/auto/jeep-wr...ath-wobble-fix
I tried for months to get rid of death wobble and steering damper wasn’t it. But thats in an XJ...
88 XJ Renix Patina Color 4:56 Gears 35" Tires Long Arm y-Link |
#2
Re: I vote lie
The true root cause of the issue was that the intake manifold has a gasket on the bottom that would leak and suck oil and vapors into the intake which would cause the pinging.
Click here to support ![]() |
#3
Re: I vote lie
20 years and they still haven't fixed it!? I find it funny the brand new $30k JL's still have this problem. Should have bought an XJ bro!
#4
Re: I vote lie
or 60 $500 XJs!
#5
Re: I vote lie
On dad's JK it ended up being the 3* of caster it had from the factory. Upped that to 7* and it went away.
I'm not a complete idiot - there are parts missing. |
#6
Re: I vote lie
I find it laughable that they're blaming the steering damper. The damper is not there to prevent vibrations and shaking. It's there to damp the steering. If you have true wobble, then you have a problem with compliance in the sytem (shot bushings, rod ends, overly flexy tire sidewalls, etc) and an alignment issue.
#7
Re: I vote lie
Vehicles with live axles have had to deal with it for at least my 60yrs !!!
#8
Re: I vote lie
That's pretty funny. Sounds about like the factory "fix" for the injector heatsoak issue on cylinder 3/4 00+... "stick a little fiberglass+foil condom on the injector, it'll make the problem go away till it's out of warranty hopefully"
My yard looks like Sanford & Sons. Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread. Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want. CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable. |
#9
Re: I vote lie
I think this is simply an inherint problem with the design of our suspension and the push for bigger and bigger tires has simply got the design to the point that the resonance frequency for the front end is now at lower highway speeds.
Could be as simple as adding some weight somewhere in the system or changing the stiffness of the sidewall of the supplied tire.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension 2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200 1982 Suzuki GS850G (barnfind project) |
#10
I vote lie
Exactly - there are too many factors that can set off a death wobble - a lift, larger tires, or some other innocuous change can cause it. A worn/defective steering damper is just one part of that puzzle. On my XJ the death wobble was caused by worn out front suspension parts. I replaced *every* moving part that could wear in the front suspension and that took care of it. |
#11
Re: I vote lie
The same truck had deathwobble so bad it snapped the passenger motor mount bolts when it was stock, and had zero deathwobble after I lifted it and installed the BFG ATs back in 2011.
#12
Re: I vote lie
OK, I'll be the one to point it out: in the linked youtube video, the crotch graphic on that woman's pants is off center. I don't think that's the cause of the death wobble, but then again I'm no automotive engineer, so what the hell do I know?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Vote for the NWC!!! | NW-ZJ-SCOTT | NorthWest Chapter | 46 | January 23rd, 2013 21:11 |
VOTE VOTE VOTE!!! | DrMoab | Intermountain Chapter | 10 | November 21st, 2008 08:23 |
Vote! | CW | Non-Tech / Off Topic | 31 | November 8th, 2006 13:05 |
