Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > ZJ and WJ Grand Cherokees (1993 - 2004)
ZJ and WJ Grand Cherokees (1993 - 2004) Technical forum for the classic ZJ and WJ Grand Cherokees.
Old June 6th, 2021, 19:03
Da XJ nut's Avatar
Da XJ nut Da XJ nut is offline
Question 42RE issues, have 93 with slipping trans
I have bought a 93 ZJ and found out after I got it running with new water pump and some exist work that the transmission is slipping in all forward gears. I have a 97 42re in storage with the harness on it and I know that the big issues with using the 97 trans is the fact it's OBD2 and the 93 isn't. Can I re wire the trans to work with my 93? Or do I just have to swap out the clutch packs and bands to fix one in it
Old June 12th, 2021, 08:53
PacificEd's Avatar
PacificEd PacificEd is offline
Re: 42RE issues, have 93 with slipping trans
What transmission is in the 1993? I have heard some of the 1993's had AW4's in them.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Current SEC Chapter Treasurer 2021-2022
Old July 19th, 2021, 13:56
Da XJ nut's Avatar
The trans is good....sorry about long delay. I just swapped out the axles to ones that were built out of a 97 that i got for free and noticed the front brake hose installed wrong position causing front brake to never fully let off making them drag hard. I fixed that when axle swapped to use the 3.73 geared and locked axles. Almost finished with that side of it then will be deciding what to do to it next...lift vs stock height and making mild overland vehicle
WTB 42re trans evowheeler Sierra Chapter For Sale 3 June 23rd, 2021 19:50
aw4 trans slipping....? fuzzydog OEM Tech Discussion 3 October 30th, 2006 15:33
93 grand cherokee 42re issues, plz help KamaZer0 OEM Tech Discussion 2 May 16th, 2006 23:20
Trans slipping? XJ Samo OEM Tech Discussion 3 September 27th, 2005 20:06
