Old April 7th, 2009, 09:38
aparke4's Avatar
aparke4 aparke4 is offline
Hydro assist help
I got this kit:
I have no fittings but i have two hoses that are long enough with the same thread male fittings on the ends of the hoses... what size fitting are for the ram? what tap do i need for my box? I have no knowledge of hydro fittings and such... thanks!
so from the ram what do i need to go in between the hose and ram? also what fitting should i run in the steering box?
Old April 7th, 2009, 11:54
Goatman's Avatar
Goatman Goatman is offline
Re: Hydro assist help
The ram is AN8 fittings, and that's what you should use for the hose ends and the fittings into the box. I'm assuming the fittings going into the box would need to be 1/4" pipe thread, then AN8 for the hose connection. Be sure to use good quality hydraulic hose.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old April 7th, 2009, 13:39
aparke4's Avatar
thanks goatman - i have some hoses that i got from PSC but some look kinda short... there is a good hydro shop near me that my friends recommended and he said they can build on the spot what ya need... anyways that is what i needed!
Old April 7th, 2009, 17:14
ROKRWLR ROKRWLR is offline
I have 3' hoses on mine. They seem to be a good length with the ram mounted on the passenger side.
Old April 7th, 2009, 20:15
aparke4's Avatar
ok great thanks i need to remeaure mine! i found a local shop just from google and they knew exactaly what i was doing! they specialize in MAJOR hydro work like the rams and pistons for construction equipment, etc... so i am going to bring my ram and stuff up there and he said he had all sorts of fancy fittings... 45*, etc... he even had some race fittinf like jegs and summit sells... i am a sucker for anything anodized
Hydro Assist 53guy SEC For Sale / Wanted Forum 3 October 29th, 2007 19:16
Hydro assist Gerr SoCal Chapter 5 March 11th, 2007 21:36
hydro assist q's bj-666 Modified Tech Discussion 8 September 27th, 2005 20:45
Hydro assist? Incredible Hulk Modified Tech Discussion 1 May 23rd, 2005 08:38
Full hydro or hydro assist?? Fore Wheeler Modified Tech Discussion 35 February 18th, 2004 19:42
