Old October 25th, 2007, 13:09
fubar XJ's Avatar
fubar XJ fubar XJ is offline
Yukon Super Joints
I ordered a set of these along with my Yukon 4340 shafts and they were troublesome to grease. They come with this copper based grease and a funky little silver pump can to lube them. The u-joints are floppy loose until you grease them up, then they "firm up" and seem solid. I was told by the guy I bought them from not to over-lube them, as you'll blow the sealing o-rings in the joint and have to disassemble and re-assemble them and start over. The question is, how do you know for sure when each u-joint cap is full of grease? The gun is glitchy, it sometimes only will pump on the last 1/2" or so of the piston, which requires a heavy hand. This doesn't allow for any "feel" for the pressure required to force the grease in. I got mine all feeling pretty solid, but didn't want to overfill them and blow the o-rings.
Any experience here?
Those Familiar with Jantz/Yukon U joints... LouisianaZJ Modified Tech Discussion 4 April 24th, 2006 06:45
OX Super Joints Loose_Nuts_Enterprises NAXJA Vendors Info and Feedback Forum 6 May 4th, 2004 12:57
Got my Ox Super Joints today Loose_Nuts_Enterprises Modified Tech Discussion 20 April 28th, 2004 19:04
RE Super Flex Joints BMP_Racing Modified Tech Discussion 1 February 10th, 2004 06:13
yukon super 35 kirby Modified Tech Discussion 4 February 8th, 2004 07:11
