Old May 6th, 2018, 17:04
Brent T Brent T is offline
Re: Pre-Production Sneak Peak at Boostwerks Comp Mount
Originally Posted by GordoSmasho View Post
That looks great. I need to get mine in still. I was working on how to go about building a bumper over it. Do you have any other pics of the tieins. It looks awesome brent.
I bought a set of "builder tie-ins from DirtBound, then cut them down and notched them to fit the 1.5" x 3" tube. I'll add a gusset later between the tie-in and the wing.
[/url]
Old May 7th, 2018, 00:40
Freida's Avatar
Freida Freida is offline
Getting this unit into place was something I knew would be a challenge. I had asked Bryson about this and he told me more
 he highly recommended a jack, such a transmission jack, and that he liked to have killed himself the first time he tried this. I donít have a working transmission jack. I didnít have high hopes for this
Old June 4th, 2018, 19:35
Here's what I ended up with for a home-made bumper. Took me way too long - I really don't have all the tools needed to do this the easy way, but it's finished now. Just needs paint and final install. Approach angle will be awesome and I'm happy with how it turned out.
IMG_0166 by Brent Taylor, on Flickr
IMG_0167 by Brent Taylor, on Flickr
IMG_0168 by Brent Taylor, on Flickr
IMG_0169 by Brent Taylor, on Flickr
Old June 4th, 2018, 20:46
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
That look awesome Brent. Nice work
Old August 24th, 2018, 12:21
Red Mistress Red Mistress is offline
Originally Posted by Anak View Post
Like this:
To be fair, there is not yet an opening in the bumper for the fairlead. I am still working on that. I will probably have to cut out the bottom third of the bumper in the center, about the width of the license plate. We will see how well the license plate hides it.
The plastic valence is necessary in order to hide the mount. It hangs lower than the bottom of the bumper. The valence will require some trimming and some different mounting holes. I have that planned out in my mind. I will post up pics as progress occurs.
About to order this after looking for years for the Ramsey 295153 Jeep special equipment hidden mounting kit. The way that kit mounted the winch was flawed and required the special winch that Ramsey made that allowed pulling from mounting feet.
The Boostwerks style is much stronger & better than OEM accessory !
Also bonus that if using the factory bumper... it doesn't have the "Bubba Gump" look extending the bumper out from body.
Have you thought about making a spacer "box" to hold fairlead ?
Could weld extension box to front of this kit allowing the fairlead to be flush as possible to go thru factory bumper. Some gussets for side pulls.
Old August 24th, 2018, 18:48
Anak's Avatar
Anak Anak is offline
Stranger
Yes. Some sort of fairlead extension is the plan. I just need to have time to work on it. Life has demanded other priorities this year, and I think I have myself already buried in projects through this coming winter.
Old November 29th, 2018, 08:21
cherokeecrawler's Avatar
cherokeecrawler cherokeecrawler is offline
I couldnít really find any other post to ask this question but how much longer is the comp mount going to be on sale?
Old November 29th, 2018, 11:40
freerider15 freerider15 is offline
Black Friday he had all items 20% off...
I think that included the comp mount.
Old December 10th, 2019, 13:56
waxer's Avatar
waxer waxer is offline
I have the Warn Zeon 8-S winch and it doesn't appear that it's compatible with this BWE Comp Mount kit.
Can anyone confirm this, or can I mod the Winch to allow it to work? I'd like to get this kit, but not if I can't use my winch with it.
Thanks in advance!
Old December 10th, 2019, 15:13
tumble tumble is offline
The comp mount is pretty tight on space, and with the Warn M8 winch the contactor is usually relocated to underneath the hood. Can the contactor/solenoid box be relocated on the Zeon 8-S?
Old December 10th, 2019, 16:30
Anak's Avatar
Stranger
How important is that bridge across the top?
From what I can see in pictures of that winch it appears that bridge is a structural component. Other designs have round steel bars which bridge the two sides. Lacking those round bars I don't see how the Zeon types would have any structural integrity without the bridge, and I don't see how you could mount one on the Comp Mount with that bridge in place
Sneak Peak:Rough Country Winch Bumper Blind Driver Modified Tech Discussion 32 September 21st, 2011 09:20
Back in production....Motor Mount Brackets Tom_T&Js_Offroad Vendor Advertisements 2 February 5th, 2009 16:09
Sneak Peak - Warrior Products XJ Rear Bumper WheelinJR Jeep Picture Showcase 7 June 21st, 2008 16:29
Sneak Peak, XJ Low Profile Roof Rack jcroffroad NAXJA Vendors Info and Feedback Forum 36 June 19th, 2008 20:22
sneak peak Led Modified Tech Discussion 43 July 16th, 2004 15:01
