OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
GM Injectors?
does anybody know of any GM injectors will swap into the 4.0?
Thanks Dan |
#2
I beleive that the 4.0 uses Ford style injectors, like those found on Mustang 5.0 enigines. Not sure on the GM ones.
#3
Heres the deal. I have a 94 LT1 Camaro and read I can put in th 30# Ford SVO injectors in it when I build it. Since the 19# Mustangs fit the 4.0, there must be one from GM that fits too but I dont follow injection too much. I am really cheap.....but....I can get GM stuff just above cost so I wanted to see if anyone knew a direct fit replacement(not Hi-Po) before I went and sat down with the catalogs to cross ref the numbers. Thanks |
#4
-88 Camaro 305 TPI
Bosch 0280150556 D5B 19lb this per : http://www.fiveomotorsport.com/Injector_SetsTPI.asp |
#5
I'm using the injectors off a 3800 FWD GM v6 in my MJ's 4.0L
I had leaky ones, no money and got these free. dunno what flow rating they are or anything, but they work better than the old ones did! |
#6
Thanks
I will look into all and let you know what I use |
Thread Tools | |
Display Modes | |
