Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
  #766
Old February 15th, 2017, 20:42
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: What are you towing with?
Owning a Nissan is like being in the special olympics..
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old February 18th, 2017, 11:02
hjeepxj's Avatar
hjeepxj hjeepxj is offline
#OCDINK
I would love to hear some specific input from people that tow with half tons.
I have a 2016 Silverado with a V8 (Z71) and the hitch has a 12,000# sticker on it.
I am curious about the prospect of towing my XJ, it would be going over passes and what not (live in CO and Moab is a must).
2000 XJ 5.5" Lift w/Deavers and TNT arms, 30 front w/Super 30 kit, ARB, truss, etc. 44 rear w/35 spline alloys, ARB, Wilwood discs, truss, etc. Hooligan stiffeners front to rear, Hooligan fenders, Trailready front bumper, JCR rear bumper w/tire carrier. *under construction*
Old February 18th, 2017, 12:26
in4aride in4aride is offline
Used to tow with my old mans 2010 f150 - v8.
Towed awesome with a double axle behind it. averaged 13 or so from springs to west slope.
Old February 18th, 2017, 12:36
hjeepxj's Avatar
#OCDINK
Nice.
Old February 18th, 2017, 15:17
Little Jeep's Avatar
Little Jeep Little Jeep is offline
I got a question about Flat towing behind a motor home, relative just purchased a MH, and a new 2016 (left over) JK unlimited. Owners manual on Jeep says flat tow (4 wheels down) with transfer case in neutral. That's it. Being a "Jeep guy", they asked me, so the question is, do you leave key in Jeep and steering unlocked, or do you set tires straight and lock steering (remove key)?
Old February 18th, 2017, 15:28
shelbyluvv's Avatar
shelbyluvv shelbyluvv is offline
Unlock the steering but put a couple bungee cords on the steering wheel to help it return to center.
Old February 18th, 2017, 15:36
Do the newer Jeeps have a position on key where steering is unlocked, but key can be removed?
Old February 18th, 2017, 19:24
Georgia Mike's Avatar
Georgia Mike Georgia Mike is offline
Just remember, simply because the hitch is rated for that weigh doesn't mean the truck is. Always look in the owners manual for the rated limit of the vehicle.
That being said, I've towed probably over a hundred times with half tons. They aren't the ultimate but they'll get it done if you're only hauling an XJ on a trailer. I'd advise you to get a transmission temperature gauge and keep an eye on it when towing.
Old September 7th, 2017, 11:10
volumeknob volumeknob is offline
I know this is old but why start a new one....
Anyone care to inform me how you're strapping the rear axle? My 8.25 has a brake line running all the way across, leaving no where to wrap a axle strap around it. Was thinking about using the leaf spring top plate as a catch but would be curious to see how you guys do it.
Old September 7th, 2017, 11:50
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
I go to the d ring mounts on the rear bumper and front tie down holes on the front. Compressing the suspension keeps it from bouncing. On long hauls I will add a strap to each axle. For the rear on my D60 there is a spot I can slip the strap under the brake line. GAMike just replaced a rear from being bent form chaining it down. At least that is what he theorizes bent it.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old September 7th, 2017, 13:06
Right on but I will not tie down with the bumpers or unibody holes. Just personal preference. I tried googling around and searched multiple forums, couldn't come up with any pics of how guys do it.
Old September 7th, 2017, 13:35
I used to loop my chain under the tube, then over the pumpkin, then back under the tube on the other side. Notice I said "used to." I wound up bending my axle housing because I was getting a bit too overzealous with tightening everything down.
I now use a JRT chain set hooked to the frame. There's a slot specifically for it just forward of the front leaf spring mount. It's a small oval shaped hole.
You'll get arguments back and forth between what's best; strapping by the axles, wheels or the frame. With our pliable suspensions I feel hooking to the frame is better, but someone else may say they feel safer hooking to the axles. I'm not sure what the DOT says. Ghost may know since he's in the trucking industry.
Good luck with it.
Old September 7th, 2017, 13:43
Just think of it like this, when they were delivered from the factory they were chained down to the car hauler through those holes in the unibody frame rails. Trust me, the metal is much thicker in the areas out back that I described in my last post. When I added my frame rail stiffeners I forgot to measure where the slots were. I went back and added my own but missed the factory holes. With my stiffeners the total material thickness was around 3/8" thick so that would put the factory holes at around 1/4" in that area due to the extra material sandwiched together there. It's made for this purpose so it's perfectly safe to use it.
Old September 7th, 2017, 13:57
I understand what you guys are saying, just want to be as safe as possible. I'm sure some of these jeeps traveled hundreds of miles that way from the factory but it still makes me nervous using that method out back. I'm also tying it down inside the footprint of the truck. So front axle tie downs come back and attach to the trailer rings under the driver seat and rear straps come forward tying in under where about the back seat is. I can do it the more traditional method of going forward with the fronts and back with the rears but I'd like to get a quad on the trailer in front of the XJ. That makes the fronts going forward impossible with the quad there....Just throwing around ideas.
Old September 7th, 2017, 14:06
That's understandable. I'm sure you've got a good grasp on what you need to do so you can fit all you need to fit on the trailer. Whichever method you decide to use, just keep it as safe as possible. I know a guy and I won't mention his name (lol) that uses one strap to the front, and one out back, both hooked to the bumpers. A couple times he's showed up to camp and the straps were hanging slightly loose haha. Pretty laid back guy and it actually makes me jealous at times that I can't turn off my "worry mode" like he can. I think since the last time that happened he's added a strap or two. I just think it's funny how stark a difference there can be in attitudes about the subject but we all still make it there, time after time lol.
Rate This Thread:
Flat Towing/Dolly Towing/Lockers ? 2xtreme Modified Tech Discussion 17 August 24th, 2018 16:31
Towing a pop-up Kevin O OEM Tech Discussion 10 January 12th, 2008 20:23
towing... mikeny59 Modified Tech Discussion 6 October 26th, 2006 14:21
Towing NOVAggie Non-Tech / Off Topic 11 July 18th, 2005 19:58
Towing randrews Modified Tech Discussion 5 March 19th, 2004 21:25
