Old April 29th, 2005, 19:43
85xjwoody's Avatar
85xjwoody 85xjwoody is offline
Question leave on A/C or take it off??
First of all lets start of with the basics,
85 wagoneer.
2.5 inline four carbed. on a fresh rebuild.
three speed tranny.
229 tranfer case.
What I want to do is leave on my A/C and remove all hoses and electrical to it and just run it like that until I get enough money together to get the right hoses and make it an air compressor. My friend is trying to tell me that the pump inside the A/C unit is always running and is taking horsepower away from me and will dry out. Is he right? I have had someone else tell me that the pump doesn't run when the electrical is unpluged and will not dry out as long as I put some lubrication it the unit once in a while and it will not take away HP. If I don't keep the A/C pump than I will be taking a measurement to get the right size belt. So who is right or are both people wrong? Any info out there would be great. Please give me some input on this or suggestions are welcome. Thanks.
Kim.
Old April 29th, 2005, 20:27
jeepsx3 jeepsx3 is offline
Thumbs up Re: leave on A/C or take it off??
Kim,
I would leave the compressor on and all the hoses so as no contaminants can get in the system which could later cause your compressor to lock up. The compressor doesn't run until you switch on the electrics which locks the clutches and then it pumps. You shouldn't be robbing horses unless it's pumping.
If the system has no refrigerant then the low pressure switch will keep it from engaging even if you move the switch to on. You can convert it to on board air pretty easily. Then you'll want to lubricate it often.
I did it to a 96xj 4.0 motor that is in a 86 CJ-7.
Old April 30th, 2005, 07:39
85xjwoody's Avatar
Thanks for the info. This helps alot. Anyone else out there with any info on this would be appreciated. Anyone else leave on the A/C unit? Or did you take it off and measure a new belt?
Kim.
Old April 30th, 2005, 15:32
rj454's Avatar
rj454 rj454 is offline
Cool Re: leave on A/C or take it off??
Kim.
Do a search on this... I read in here somewhere a post about converting the A/C to an air pump by adding an oiler to the inlet and an oil trap/filter(?) to the outlet. This keeps the unit oiled and ready to go anytime. It is something I plan to do whenever I feel itchy and have the time.
And if you find it; please post the link to it here so everyone can find it.
Old May 1st, 2005, 11:34
BrettM's Avatar
BrettM BrettM is offline
make it into an air compressor, one of my best mods, very useful. do a little searching and you will figure it out real easy
Old May 1st, 2005, 16:38
85xjwoody's Avatar
Thanks for the suggestions. I did leave it on and is working fine but now I have other problems that I have a few questions about so I will have to start a new thread. Serious vacuum problems.
XJ Sport A/C Control Question Quarterwave OEM Tech Discussion 14 July 30th, 2005 15:51
Cooling and A/C note and question RichP OEM Tech Discussion 1 June 19th, 2004 12:19
a/c wiring connector Deyman OEM Tech Discussion 3 May 24th, 2004 06:13
A/C compressor info 01xj OEM Tech Discussion 11 July 3rd, 2003 18:00
A/c Help Rescue Ray OEM Tech Discussion 8 April 11th, 2003 19:36
