Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Red River Chapter
Red River Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old October 5th, 2009, 13:21
WesXJC's Avatar
WesXJC WesXJC is offline
Parking an XJ
I ship out to AFBMT in January, then to my Tech school after, so who knows how long I will be away from my precious wagon. What are some things I need to do to prep it for being parked for a while when I'm gone?
Old October 5th, 2009, 13:31
x2elite x2elite is offline
Re: Parking an XJ
put some fuel stabilizer in the tank for sure.
Old October 5th, 2009, 13:56
wheelinscott wheelinscott is offline
Re: Parking an XJ
get the tires off the ground so you dont get flat spots in them. if your going to be gone as long as i think id almost drain the gas. where is it going to be parked. will it be covered or what?
Old October 5th, 2009, 14:18
Swamprat Swamprat is offline
Re: Parking an XJ
take out the battery, or at least disconnect it. the little smell god trees never hurt, im sure google might yield some more info
Old October 5th, 2009, 14:39
Re: Parking an XJ
Yeah I would drain the fuel, or put stabilizer in it, disconnect the batter, probably try to get the tires off the ground to keep from getting flat spots, and dry rot, and I would very likely put some mothballs under the hood, and in the interior to keep varmints away.
Old October 5th, 2009, 15:17
magimerlin's Avatar
magimerlin magimerlin is offline
Re: Parking an XJ
NO NO do not drain the fuel. Actually fill it up then put stable in it. If the tank is empty condensation will build up and rust out the tank. Definitely get the tires off the ground though and disconnect the battery.
Old October 5th, 2009, 15:21
ridgerunner97 ridgerunner97 is offline
Re: Parking an XJ
Hmmmm, XJ with a rusting gas tank? thats new to me LOL I thought they were all plastic tanked?
Old October 5th, 2009, 16:22
$450JEEPxj $450JEEPxj is offline
Re: Parking an XJ
You can bring it with you to Lackland AFB I will be more then happy to look after it for you while you are here.
The fuel tanks on the four XJ i have own have all been metal tanks with plastic covers.
Old October 5th, 2009, 16:38
magimerlin's Avatar
Re: Parking an XJ
X2 they are all steel that I have seen and owned. As stated there is a plastic shield that is on the bottom of them to help against any bad (normal driving/not wheeling) crap.
Old October 5th, 2009, 16:40
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Re: Parking an XJ
Agreed. If you're going to drain the fuel you'd have to drain *all* of it which is not a realistic goal.
1984 - 1996 tanks are steel. 1997 - 2001 tanks are plastic.
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old October 5th, 2009, 20:01
WesXJC's Avatar
Re: Parking an XJ
I secured a spot in my sister's garage for it to rest while i'm away. Anyone have any ideas on how to get the tires off the ground? Dismounting them and leaving it on jackstands makes me feel uneasy
Old October 5th, 2009, 20:41
GSequoia's Avatar
Re: Parking an XJ
Just get some shorter jack stands and put them under the axles leaving about a half inch of air under the tires. This way if a jack stand fails it won't fall far nor enough to hurt folks and objects near it.
Us normal people...
Old October 6th, 2009, 10:05
Re: Parking an XJ
Well hot damn, ya learn something new every day! I thought they were polyethylene plastic the whole way through. Thats cool and good to know. Haven't had to screw around with the ole tank yet knock on wood so I was unfamiliar with em.
Rate This Thread:
Parking troubles... ExTankerGuy Red River Chapter 3 May 29th, 2008 16:44
Parking the XJ 1990XJ4x4 Non-Tech / Off Topic 7 January 27th, 2006 10:28
jagoffs in the parking lot Darky Non-Tech / Off Topic 28 October 1st, 2004 20:57
Parking tow rig Goatman XJ Fest 2004: Rubicon 1 February 9th, 2004 06:36
Odd Parking Gecko Non-Tech / Off Topic 1 October 24th, 2003 02:10
