Old April 25th, 2006, 14:27
jeepboy_90's Avatar
jeepboy_90 jeepboy_90 is offline
Intake Manifold Upgrade
Will the 99,00,01 manifolds all work on a 98 4.0? Will Grand Cherokee manifolds work? What is good price for a complete manifold?
Old April 25th, 2006, 15:10
TLange TLange is offline
Re: Intake Manifold Upgrade
That is a common upgrade for the Jeep Speed folks. It will fit but you will need all power steering brackets that go with it.
Old April 25th, 2006, 16:59
joshv98xj's Avatar
joshv98xj joshv98xj is offline
It will work on a 98. I just picked up an intake manifold off of a 99 grand for my 98 4.0. I also picked up the Banks look-a-like, and I'm gonna do em both at the same time. You only need new power steering stuff on the pre 97. I picked up my manifold, complete with fuel rail, injectors, and throttle body from a local junkyard for $125. That seems to be about average, unless you can get it from a u-pull-it yard. I'm keeping my 98 injectors and TB, and I'm gonna throw the rest on ebay.
Old April 26th, 2006, 01:03
Gojeep's Avatar
Gojeep Gojeep is offline
Mine came off a TJ and worked exactly the same. I have even the dyno charts now given to me by someone that had used my write up to install theirs. www.go.jeep-xj.info
Intake manifold itadekimasu OEM Tech Discussion 2 October 18th, 2005 09:31
99+ intake manifold joshbish Wanted: Private Party Only 2 December 3rd, 2004 20:48
intake manifold upgrade? willy3 Modified Tech Discussion 6 July 11th, 2004 12:20
98+ Intake Manifold XJ91 Modified Tech Discussion 16 March 5th, 2004 13:01
does anyone have a HO 4.0 intake manifold norcalxj Sierra Chapter 16 September 10th, 2002 18:59
