as long as it has disc brakes it's the same as any other. They were all 31 spline, and the only difference between a v8 one and a v6 was some brackets mounted to the diff.
If you're planning on getting a lunchbox locker or mini spool make sure you get one with an open diff. Otherwise you can rebuild the LSD while your changing gears.
check over at one of the ranger/explorer boards for a list of tags and what they mean.
As far as I know there isn't a difference in length between the years. I went with the 98 just because that's what I found a deal on. It does make the width a bit shorter but im planning on installing the C-clip eliminator from superior when I get the money. Also, the drive line is moved over to the passenger side a bit. Not too big of a problem unless you have a big muffler.
the only wider 8.8s are full size, and the mustang 8.8s aren't 31 spline or the proper bolt pattern.
spacers or a super 88 kit to get the width proper.
this has been covered over and over. just look at the bottom of this page for links to 6 other threads about the 8.8
