Just Differentials
Differentials and Axles!
- Washington State
If you haven't regeared yet, or don't fully understand why it's important...
Read Below:
Even slightly larger tires change the RPM at which your vehicle was designed to shift gears, creating more heat, wearing out your transmission and drive train pre-maturely. This, and adding heavy accessories, also puts more strain on your engine and transmission, greatly reducing your power and fuel economy. By changing the gearing, and effectively the gear ratio, you can easily take back all that power, fuel economy and reduce wear, adding years to your vehicle.
Find the perfect Gear Package for your XJ HERE
Read Below:
