Old September 18th, 2019, 09:02
jmg222 jmg222 is offline
replacing seals around window...
complete newb question was trying out a different rune profile on my motor last night, and noticed that the seals -- the exterior rubber whether stripping that frames the window-- around the door windows are all shot (I had rolled my truck two years ago, the doors are all donors). since I've replaced everything else on the dammed thing, may as well replace those. Never done it before, prefer not to use the trial-and-error method. what's involved in doing this? where can I buy new seals?
Daily drive: 2018 Jeep Grand Cherokee TrackHawk; stock (for now)
Trail ride: 1988 XJ: Motor/plumbing/electrical: '19 ZZ6 350 sbc, 420HP/405 lb-ft; holly performer EPS, Terminator EFI, headers, novak aluminum radiator; MSD ignition
Drive train: d30 front, F8.8 rear, 4.11 gears, np242 transfer case, rusty under-armor; fully locked with detroit lockers; Chevy 700r4 tranny, 35" MT's
Old September 18th, 2019, 11:38
jrmyers's Avatar
jrmyers jrmyers is offline
Re: replacing seals around window...
https://lmgtfy.com/?q=how+to+replace...j+window+seals
jrmyers's Avatar
https://www.youtube.com/watch?v=1ZeCWaM5nIk
Old September 18th, 2019, 11:59
deesiexj's Avatar
deesiexj deesiexj is offline
I just replaced mine and got the seals on teamcherokee.com. Good fitment, nice and flexible too, definitely better than the 25 year old torn ones I had. I was replacing window glass at the same time, so I had the entire window and wing window assembly out, it was a very simple exercise at that point.
They just clip into place, no glue or anything, so it is just a matter of persuading the old seals out and getting the new ones lined up properly.
Old September 18th, 2019, 12:54
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is online now
Originally Posted by jrmyers View Post
I haven't shelled out the coin to do this, but I've read once replaced it's common for the doors to take a bit more effort to shut. Just fyi if you do and it's not as you remembered.
Old September 18th, 2019, 13:56
old_man's Avatar
old_man old_man is offline
The Uchannel felt that is on the sides of the window, is fairly generic and is available cheap at rockauto.com
The wipe seals is a bit harder to find. rockauto used to have it but I haven't checked lately.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old September 19th, 2019, 08:32
thanks!
Replacing Seals - long winded question Kevin OEM Tech Discussion 1 April 11th, 2010 20:34
replacing seals & gaskets? cracked-butt OEM Tech Discussion 15 March 31st, 2010 21:10
replacing valve stem seals justright92xj OEM Tech Discussion 5 April 20th, 2006 17:07
replacing d30 seals Kejtar OEM Tech Discussion 9 May 11th, 2005 07:31
