Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > Cherokee Crawl 2015
Cherokee Crawl 2015 July 3rd - 4th, 2015 - Black Mountain Off Road Adventure Area - Harlan KY Event sponsored by H.D. OFFROAD ENGINEERING
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  #16
Old February 4th, 2015, 08:16
JRT1393 JRT1393 is offline
Re: Things to do before the Crawl.....
-Part out parts ZJ for crawl money
-Put parts ZJ engine in XJ to get rid of the one with the hole in the side of the block
-Track down a way to tow the thing up there
Rear end
-Throw D44 under rear
-Mini spool in D44
-Bastard pack w/ new bushings and bolts
-Bump stops
-Repair rear upper shock mounts
-Bar pin eliminators
Front end
-Rebuild RE LCA's and install
-Replace front drive shaft
-Front locker
-Bar pin eliminators to fix shock mounts
-Bump stops
-Simple bumper?
Armor/protection
-Install TC skid
-Track down and install gas tank skid
-Rocker protection
-Rollover protection of some sort
-Frame stiffeners?
  #17
Old February 5th, 2015, 06:58
downs807's Avatar
downs807 downs807 is offline
JRT sounds like your going to be a busy man between now and the crawl. I did manage to get my mega bump stops mounted. Total of 7inch in the rear with 4 1/2 in up travel and 4 1/2 in the front.
  #18
Old February 5th, 2015, 08:15
Yeah hopefully Spring break is going to be my saving grace. Honestly the biggest challenge is going to be finding a way to get it towed up the mountain. Although I believe a buddy of mine may be able to help me as long as I can track down a trailer that can fit both my XJ and his Bronco on it, which would be a challenge in and of itself
  #19
Old February 8th, 2015, 10:20
UNCC_99XJ's Avatar
UNCC_99XJ UNCC_99XJ is offline
Twisted Up
Fix my tcase (in progress)
Replace control arms
Whatever else decides to go wrong between now and then.
-Timbo -
-'99 Sport, RE 4.5" and a few other things
-'13 Performance Blue Ford Focus ST. DD & Race Car.
-'17 Ruby Red F150 Lariat. Tow rig and occasional DD
  #20
Old March 16th, 2015, 16:37
Buzzstrike's Avatar
Buzzstrike Buzzstrike is offline
Oh how true...
For my first crawl with yuns, I hope to have the Durango steering box installed along with my new front bump stops this week.
But hopefully before July I'll get my rock rails built up and installed and IF I'm lucky get the 4.56 gear sets in. 33" with 3.55's against the AX-15 4.0, it's a bit sluggish.
Endeavor to persevere. Every day.
  #21
Old March 17th, 2015, 00:03
IllianaXJ's Avatar
IllianaXJ IllianaXJ is offline
Support Your Local Trails
Originally Posted by IllianaXJ View Post
Mostly depends on what happens at WinterFest.
Need to throw some 134a in it, probably do that at the campground. A rear locker would be nice. Wouldn't hurt to go over the cooling system.
Well, new list.
- Put together new front axle housing
- Figure out what CAs to go with
- Radiator/lower hose/check water pump
- Finish tire carrier install
- Rear locker
- Recharge A/C (maybe this should go to #1 )
- Grow money tree to feed the Yukon's 87 octane habit
Originally Posted by Buzzstrike View Post
yuns
I thought my wife's grandmother was the only one that said that.
MWC Vice President
1995 XJ Sport Mallcrawler build
2009 Chevrolet Suburban K2500 6.0L/6L90
  #22
Old March 17th, 2015, 07:26
043500 043500 is offline
Got my tires and rims on, made a spare tire mount.
Now I just need to do an oil change in the tow rig and the MJ and pretty much we're ready.
1987 MJ renix 4.0/AW4, D300, 60/14B welded 5.13's and 37's.
1993 XJ 2 dr, 5" lift and 32's
2003 dodge ram 3500 cummins
  #23
Old March 18th, 2015, 09:21
UNCC_99XJ's Avatar
Twisted Up
Well, new list.
- Rear locker
If you haven't got your AC working by the crawl, let me know and I can work some magic on it in Harlan
-Timbo -
  #24
Old March 18th, 2015, 13:59
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Since I no longer have to worry about putting air in my front tire I might consider hooking my radio back up in the Jeep.
  #25
Old March 26th, 2015, 10:09
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Originally Posted by Ghost View Post
Things I have to do as of now:
New rear shocks
Fix running lights.
Things I would like to do.....
Strong Box
Lighten
More power
Lower it again: (Might have to look into ORI or Coil overs for this.)
So this list got thrown out the door:
New list:
Rear Bar tubes
Repair Fuel Pump Ground
Taillights/fix headlight switch
fix rock lights on front
fire extinguishers
tool storage tie downs
Mount spare driveshafts
New tie rod (waiting on Ironman Andy to ship)
35 spline stubs and flanges
tune up, fuel filter, air filter, plugs
address noise under hood, suspect e fan
maybe move power steering cooler to the rear cage
steering column
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
  #26
Old March 26th, 2015, 11:28
I have to add a track bar to my front suspension. I have the bar and made the brackets/mounts out of 1/4" steel...now I just need to get it all welded up ...dammit I gotta learn how to weld!
I also need to move my battery...I had to put in another one as the old one died...this one is a lot bigger. I did some 'massaging' and made it fit but it's still too close to the mech fan.
  #27
Old March 26th, 2015, 21:26
Ghost's Avatar
Member Number 257
New list:
Rear Bar tubes Done!
fire extinguishers
steering column
  #28
Old March 27th, 2015, 06:39
Lowrange2's Avatar
Member# 2368
OH! I have to do something before the crawl.
I have to replace my front left brake caliper.
  #29
Old March 30th, 2015, 09:14
Ghost's Avatar
Member Number 257
New list:
Taillights/fix headlight switch Done!
fire extinguishers
steering column
  #30
Old March 31st, 2015, 15:29
shortxjdoug's Avatar
shortxjdoug shortxjdoug is offline
i will be bringing this.... hopefully it will look different by then
Rate This Thread:
Things to make the crawl better - 2012 RedHeep Cherokee Crawl 2012 15 July 11th, 2012 11:15
A Few Things. Pretty Big Things Stukboy NAC Classifieds 15 March 23rd, 2012 23:05
Things that'll make the crawl better RedHeep Cherokee Crawl 2010 39 July 12th, 2010 04:16
Things I learned at The Crawl FlexdXJ Cherokee Crawl 2010 42 July 9th, 2010 07:58
WTB things and selling things Swamprat Red River Chapter For Sale/Wanted 18 January 1st, 2010 23:57
