Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
  #31
Old November 22nd, 2019, 19:14
RCP Phx RCP Phx is offline
Re: 2000/4.6/Screamin-Demon/Holley MSD
It works!!! Tomorrow will be the real test to see if this was really worth it.
Old November 23rd, 2019, 13:40
Well it doesn't work and I will have to wait till Monday to see if MSD has a answer. I was afraid of this, the PCM doesn't see the full coil current since it's only being used as a trigger input. I'm getting codes 351,352,and 353. I'm back on the bypass now so well see if the PCM can handle the current.
Old November 26th, 2019, 11:25
I've been on the phone with MSD the last couple days. Since it runs but the PCM shuts it down, they think I need a new adapter that's just started production. They are supposed to send me info on the adapter.
Old November 27th, 2019, 10:23
I just spoke with MSD, they said call back next week because the tech/production staff is on Thanksgiving vacation. He did still say it's under re-development so I don't really know what that means yet. It definitely seems to be what I need to make this work. I just hope that it's not like the pistol I ordered and paid $5k for 16 months ago and still don't have a completion date!!!!
Old December 2nd, 2019, 09:01
I spoke with every department(including ordering which I did) in a effort to light a fire under them. I've even got a claim in with the warranty department to not start until I receive the adapter. The production department is still doing testing and don't have a date for me. I've spoke with everyone at Holley regarding them marketing a direct fit for the MSD when I need a adapter that's not in production yet, kind of mis-leading as I wouldn't have purchased it otherwise!
Old December 6th, 2019, 17:01
Got a call from MSD today on the dimensions. I has to "shoehorn" the MSD in so I will be looking closely at it this weekend. They also stated they didn't think that the adapter would be out until February!
Old December 12th, 2019, 07:56
Good new, I hope! Holley just E-mailed me a shipping confirmation. I need to get things ready this weekend.
Old December 18th, 2019, 07:11
I received my MSD adapter last night, I need to decide how I want to wire it in. I did order and receive a 8 pin connector but I may want vhange to (2) 4 pin connectors or just wire it in hard.
Old December 19th, 2019, 20:14
Well it's running Tomorrow I'll get a chance to fully check it out. I'm unable to add pics right now so I can't show you the new harness.
Old December 21st, 2019, 10:34
Took it out this morning to do a hard run. It's cutting out on the top end so either I don't have the rev limiter adjusted correctly or there is "something" wrong, don't know what that would be though?
Old December 21st, 2019, 10:53
[QUOTE=RCP Phx;246668288]From post #7
Here's the answer, I set the rev limiter to 4600rpm. I will adjust it to 6000rpm and go for a new test.
Old December 21st, 2019, 14:43
That was it, I didn't get a chance to run it all the way(cause DPS was on the freeway), but I'll give it a hard run this evening.
Old December 24th, 2019, 05:43
Photobucket is still down so no pics. In the mean time it's running great, I will head out about noon today for California for a mileage check. After that on the 8th I've got the dyno scheduled, that gives me time to re-install my #27 injectors. On the 24th I hope to take it to the dragstrip and get some times documented.
Old December 27th, 2019, 16:20
Scrubber3 Scrubber3 is offline
Thanks for the effort doing this.
Old December 28th, 2019, 09:57
Photobucket is up for a bit so........ here's the new adapter and the harness I made.
Rate This Thread:
Anyone w/ a '00-01 and a Screamin Demon coil? RCP Phx Modified Tech Discussion 9 November 2nd, 2019 08:00
IM GONNA START SCREAMIN SOON!!! jmeti000 OEM Tech Discussion 15 January 8th, 2009 07:30
screamin deal on axles. I think? noobie2Cherokee Modified Tech Discussion 4 November 3rd, 2006 15:43
Screamin' Demon drifting_home Modified Tech Discussion 3 May 5th, 2005 18:24
3.4L XJ...holley or not? myjeepsbigger Modified Tech Discussion 9 September 24th, 2003 21:55
