Old January 31st, 2018, 12:42
Tardis XJ's Avatar
Tardis XJ Tardis XJ is offline
Smile AW4 Trans Yoke length
I have a '89 XJ, 4.0 mpi, AW4, NP 231, 4 door that I just replaced the Dana 35 rear axle, and it appears that the yoke on the transmission end of the drive-shaft is now just barely long enough to keep a seal (no fluid leak has been detected). Q, are there different lengths for the 27 spline AW4 transmission yoke? If so, who sells them? I'm already grateful for any help I receive here.
Old January 31st, 2018, 18:29
lawsoncl lawsoncl is offline
Re: AW4 Trans Yoke length
You replaced the axle and now the driveshaft seems too short? Or was it too short to begin with? If it's a new problem, double check that the new axle is rotated properly and sitting in the correct position on the leaf springs. Did you swap in a newer D35 (the newer c-clip version has a rubber fill plug instead of a threaded metal one)?
There are at least two different length rear shafts, depending on the transmission and xfer case. The automatic trans is about 1" longer than the manual. Lifting the XJ can also require a longer shaft.
Old February 11th, 2018, 11:00
Tardis XJ's Avatar
Question Re: AW4 Trans Yoke length
Thanks for the info, but I asked about the YOKE LENGTHS and not the drive shaft lengths. I've seen longer length yokes for lots of different transmissions, just not for the AW4--I'm looking to find the length of the longest 27 spline yoke for the AW4. Do you know what length the longest yoke might be?
Old February 16th, 2018, 12:36
Jim Malcolm Jim Malcolm is offline
You sure you're not looking for a yoke for a NP231, not an AW4?
One from a YJ is what you're looking for. They're 1/2-3/4" longer, can't remember which. A SYE is the better choice.
HP D30 yoke bolt length? ChuckstrPT Modified Tech Discussion 0 September 5th, 2009 06:26
Hack-n-tap out put yoke length Mike1331 Modified Tech Discussion 4 July 16th, 2008 11:17
Pinion Yoke Length? St3mpy OEM Tech Discussion 0 April 27th, 2005 17:44
Slip Yoke Length lickdj Modified Tech Discussion 1 December 6th, 2004 11:39
Slip yoke length rusty1007 OEM Tech Discussion 4 March 19th, 2004 20:27
