Old November 16th, 2009, 18:26
bakerboys's Avatar
bakerboys bakerboys is offline
Trany Help
1996 Xj was fine but drove it tonight and check engine light came on
Trans does not come out of second I HOPE that does not mean tranny is bad any suggestions fluid is good dont know last time it was changed only had jeep on road for 1 week
Old November 16th, 2009, 18:42
Skwerly Skwerly is offline
Re: Trany Help
Have you eyed the linkage?
Old November 16th, 2009, 18:55
bakerboys's Avatar
Re: Trany Help
no it was driving fine
bakerboys's Avatar
Re: Trany Help
I did adjust the nuetral saftey switch
Old November 16th, 2009, 19:09
bakerboys's Avatar
Re: Trany Help
I just tried it again I WAS WRONG it wont shift out of 1st
PLEASE HELP
Old November 16th, 2009, 19:11
JJacobs JJacobs is offline
Re: Trany Help
Unplug the TCU (transmission control unit) and see if it will shift manually.
And learn to use the SEARCH feature.
Old November 16th, 2009, 19:16
bakerboys's Avatar
Re: Trany Help
I did the search feature but it showed 1 transmission forum if you dont mind where is the TCU
Old November 16th, 2009, 19:18
joe_peters joe_peters is offline
Re: Trany Help
Under the dash by the glove box, I believe, and the later models it was moved to the drivers side.
Old November 16th, 2009, 19:20
bakerboys's Avatar
Re: Trany Help
OK If I unplug the TCU what is that suppose to do
Old November 16th, 2009, 19:24
Re: Trany Help
It will disable the transmissions electronics.
If it will shift as you move through the gears manually, then you will know that your problem is in the electronics and/or wiring.
There is an in-line fuse to the TCU, there are solenoids in the transmission, and multiple inputs to the TCU that can screw things up. If it still won't shift with the TCU unplugged then you have a mechanical or hydraulic problem.
Did this happen right after you worked on the NSS? Did you get the mounting nut too tight--that happens fairly often.
Old November 16th, 2009, 19:29
bakerboys's Avatar
Re: Trany Help
well 3 days ago i adjusted nss we have driven probally 200 miles since
Old November 16th, 2009, 19:30
bakerboys's Avatar
Re: Trany Help
I will try that switch
Old November 16th, 2009, 19:36
bakerboys's Avatar
Re: Trany Help
Mr Peters
I have looked and I have no idea what the TCU looks like or online what would it look like thank you so much
Old November 16th, 2009, 19:51
Re: Trany Help
Originally Posted by bakerboys View Post
Mr Peters
Just Joe.
Photo that kastein posted: http://www.naxja.org/forum/showthread.php?t=1014856
Old November 16th, 2009, 20:51
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Re: Trany Help
That's a pic of a 97+ TCU actually - the 96 TCU looks very much like it, but larger (about the size of a package of PopTarts, but 3x thicker.) It's located on the back of the lowest plastic panel for the passenger side of the dashboard. You can see it if you stick your head under the dashboard by the blower motor and look back up toward the seats.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
trany swap dobbs571 OEM Tech Discussion 4 June 23rd, 2008 20:24
'97 trany bluedevils278 OEM Tech Discussion 24 December 1st, 2007 18:58
'97 trany bluedevils278 OEM Tech Discussion 0 November 10th, 2007 19:26
t5 trany pb_beaker OEM Tech Discussion 0 July 15th, 2007 11:24
What trany do I have? brian OEM Tech Discussion 3 June 4th, 2003 07:21
