swapping manual window/door controls onto power door
k-bay xj
NAXJA Member #1356
Va Beach, Va
Hey everyone, I have been a member for a while and just been searching the forums to learn all I can about my XJ. There is some really great info in here.
Here is my question: All four of my doors are pretty rusted out, and I will be getting four doors off of a donor for free. The only problem is that they are power window and locks, and I have a manual setup. Will it be possible to just swap out all of the manual stuff into the power doors, or do I have to keep the power setup and wire it in. I would rather keep the manual stuff, as it is less prone to problems than the power setup.
My vehicle is a '91 Xj (not sure about what model, it is an old government surplus vehicle, bought for $400 from DRMO).
The donor is a '89, not sure what model either.
Any help would be appreciated, thanks.
Matt
it takes some time but is rather simple, remove your power tracks/motors and replace with the manual stuff, pretty much that simple.
you will need a big rivot gun or you can bolt the stuff back in with small bolts.
super easy swap.
dan
Hey thanks alot for replying. I figured it would be that easy, but wanted to get a little input before I started tearing things apart.
Matt
