Old November 25th, 2007, 17:51
mjdavis31's Avatar
mjdavis31 mjdavis31 is offline
1979 bronco axle swap help
I plan on running axles from a 79 bronco I picked up, from what i have read the 79 bronco front axle isn't the best choice, could i get a housing the same width from a truck and use everything else from my 79? any other ideas help thanks.
Old November 25th, 2007, 17:54
whitneyj whitneyj is offline
Re: 1979 bronco axle swap help
I know that you can use the outers for sure, you'll have to match up the axle shaft length for the inners. From what I've read it'll be tricky to find one. I just had a thread about this same axle, scroll down to check it out.
Old November 25th, 2007, 17:55
ZacSquatch's Avatar
ZacSquatch ZacSquatch is offline
Yeah, the f-150's are pretty much the same WMS...
Old November 25th, 2007, 18:02
TNT's Avatar
TNT TNT is offline
Seasoned Veteran
Get a 73-77 F-150 HP D44 it uses the same shafts and has 1/2" wall 1 piece axle tubes.
Old November 25th, 2007, 18:03
mjdavis31's Avatar
thanks thats what i thought.
1979 F150 rear axle seal. ColoradoJeepXJ Tow Rigs and Trailers 1 August 14th, 2007 17:58
Early bronco 44 swap Gold Cobra Modified Tech Discussion 2 May 30th, 2007 13:22
Dana 44/Ford 9" out of 1979 Bronco? Menzenski Modified Tech Discussion 8 April 12th, 2006 02:19
1979 Ford dana 44 bronco 4x4forlife Modified Tech Discussion 4 November 11th, 2004 16:43
Removing front D44 axles (1979 bronco) CJS Modified Tech Discussion 3 May 10th, 2003 06:53
