Old September 11th, 2019, 12:39
RCP Phx RCP Phx is offline
Re: 4.7 stroker, whatchu got?
Crane is still in business, maybe under new onwership but ....
https://www.summitracing.com/parts/crn-753901?cm_mmc=ppc-google-_-search-_-brands-_-keyword&gclid=CjwKCAjwtuLrBRAlEiwAPVcZBnN4qn5gk2uF ziQgnGdUY9IWQKePLIj5qMbBgFeAJCbONLDsdfS-IRoCtocQAvD_BwE
Old September 13th, 2019, 14:18
old_man's Avatar
old_man old_man is offline
Thanks for the info. I am running the Crane 753901 cam. I love it.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old September 13th, 2019, 15:47
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I just did a fresh one.
https://www.naxja.org/forum/showthread.php?t=1152254
Old September 13th, 2019, 16:37
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
That's a few folks thus far. Not quite as common as use thought?
Cal you went all out
Old September 13th, 2019, 17:15
cal's Avatar
cal cal is offline
More common than you think, this forum is slow these days. Facebook is killing the internet.
Old September 13th, 2019, 17:43
Russ definitely puts his best in every build, but you need pretty deep pockets!
Old September 13th, 2019, 17:44
cal's Avatar
cal cal is offline
His kits are pretty affordable. Its his labor that you have to pay for.
Old September 17th, 2019, 07:59
Anyone run 12 hole injectors on a stroker, can't say I've ever read about it?
Old September 17th, 2019, 08:18
There's no advantage.
Old September 17th, 2019, 12:30
cal's Avatar
cal cal is offline
Every 12 hole injector I have looked up has been intended for engines with 2 intake valves. The holes are angled to spray outward and not strait down, to spray into both valves.
On our 1 valve engines, it causes them to spray onto the valve seat and causes the fuel to bead up.
Not to mention they are 19 pound injectors too small for a stroker, and the commonly sold ones in the XJ groups appear to be knock offs and not legit Bosch.
Old September 18th, 2019, 07:32
Have any of you replaced the aw4 for a trans with a few more gears or is the aw4 enough? I know it'll handle it fime, I'm thinking of driving comfort(highway). Especially if your geared down.
Old September 18th, 2019, 07:35
cal's Avatar
cal cal is offline
There's a current project to mate the W5A580 from the 3.6 JK up to a 4.0, but no one has made it work yet.
I know a few people have done 700r4's (and there are kits for it) but there's no real gain to be had there.
Old September 18th, 2019, 07:36
cal's Avatar
cal cal is offline
One guy did successfully mate an AW4 up to a 6.0 LS in an XJ, but the trans didn't last very long..
Old September 18th, 2019, 08:06
Not to many auto's for the 4.0, but you could do a NV3550.
Old September 18th, 2019, 08:19
Not sure what you meant by comfort but they originally took mine to a 100mph when it was on the dyno. I constantly run at 80mph before my tire balance starts to feel "off". What more are you looking for?
Will my stroker beat CRASH's stroker? Goatman Jeep Street and Performance 29 February 24th, 2018 20:45
4.7 stroker POLAR_JEEP_04 Harlan 15th birthday Swap Meet 13 June 3rd, 2014 15:28
Test Results from Stroker Overheat (Overheated the Stroker Badly- Part DUEX) NHxj4x4 OEM Tech Discussion 36 January 24th, 2010 17:54
Finally took apart my Stroker (Stroker Overheated Badly) Part Trois NHxj4x4 OEM Tech Discussion 7 April 15th, 2008 10:45
what to get for a stroker rojofixj Modified Tech Discussion 2 November 16th, 2006 06:49
