Old August 12th, 2020, 10:24
Frakkedup Frakkedup is offline
Help needed to identify what this is.
Hey all, new to forum and xj's, owned it a cpl of weeks and working hard on it, the steering column was in pieces and I have a piece which I cannot identify, maybe you could help, I was pulling the cover of the column and a piece dropped out what is it and where does it go? My searching on diagrams of steering columns didn't yield any results.
It's a 93 XJ
Old August 12th, 2020, 10:29
RCP Phx RCP Phx is offline
Re: Help needed to identify what this is.
A pic???
Old August 12th, 2020, 11:05
For some reason image didn't show on initial post
https://imgshare.io/image/NEQFkZ
Old August 12th, 2020, 11:48
Black1990jeep Black1990jeep is offline
I looked in my factory book for a 1990, did not see that part but the diagrams in the book dont show everything. however found this...
https://www.fixya.com/uploads/images...1_14_04_pm.jpg
it is from a 1990 Wrangler. the "ignition switch actuator rack" looks simular to the part you showed. Not the same, but simular.
Does everything work on yours with that part not in it? will jeep start? accessory position? does the ignition lockout if tranny not in Park? do the signals work, do signals self cancel after a turn? hazard lights, cruise control, horn, wipers, washers, high beams, etc... function as normal? check all the steering column functions, as likely one or more of them wont work with that part missing. that will help you identify it by knowing what function it effects when missing.
good luck.
ps also when reassembling, remove old grease and dirt on the sliding , rotation, cam surfaces, then regrease with clean plastic compatible dielectric grease. use dielectric grease so that it wont cause a short circuit the grease bridges over electric contacts.
the lock cylinder should be lubed with dry graphite, "key lock lubricant". blow it into the key hole and then work the key in and out/ rotate to work the graphite in. Graphite is conductive so only use in the lock cylinders while you are at it, lube the other key holes on doors and hatch , then do your house door locks. this should be a yearly thing on your car(s), house, and Jeep locks.
Old August 13th, 2020, 19:37
Ridered4583 Ridered4583 is offline
That Piece pushes the rod that pushes the ignition switch I do believe. If you just got a jumble of parts out of your column good luck with that jigsaw puzzle. You will definitely want a manual or even perhaps worth pulling the wheel off one at a junkyard just to see and take pictures. Also if that fell out on its own there are probably a few other pieces you will need! Good luck. I have had no fun re-assembling steering columns myself.
Old August 13th, 2020, 23:46
uglyrenixxj uglyrenixxj is offline
High beam switch actuator.....and it is a BEAR to get back in.
Old August 14th, 2020, 07:02
Many thanks to black1990jeep, it was indeed the high beam switch actuator and it was a biatch to put back in, column is now complete and steering wheel going on today, discovered horn is pooched as is steering lock and key cylinder as well, so looking at wiring in a toggle switch and push button start, it's only going to be a trail rig, so not concerned about security as it will be garaged.
You guys rock with your help
Please Identify roboter OEM Tech Discussion 4 November 13th, 2016 18:17
Help needed! Identify this bolt found loose in oil pan? Red91Laredo OEM Tech Discussion 40 November 29th, 2012 09:58
D30 identify ebyrd10000 OEM Tech Discussion 6 May 18th, 2009 08:34
identify this please Nomercy Modified Tech Discussion 8 October 25th, 2008 21:23
Please help to Identify Mr.G & Family OEM Tech Discussion 23 March 26th, 2008 08:16
