ddeadserious
- Detroit
1992 Jeep Cherokee Pioneer
I need something less extreme and nicer looking. I just don't have the time or money to go wheeling and I'd rather see it go to someone who will use it for what it's built for.
THE BAD:
THE SPECS:
133,XXX Miles
Drivetrain:
Axles:
Dana 30
Ford 8.8
Suspension/Steering:
Tires:
Interior/Audio:
Exterior:
PARTS INCLUDED:
$3200
Will consider a trade for a mildly lifted(0-4") 94+ ZJ(no 249 t-case) or 97+ XJ(no 4cyl or manual). We can talk about more what I'm looking for and things if someone's interested in a trade. No trade for any other vehicles than XJs or ZJs.
I'm located about 20 minutes west of Detroit and will meet within an hour to show this to someone or 2 hours to sell/deliver it, assuming I get some kind of deposit on it.
THE BAD:
- Rear CV Joint is going out, just making the card in spokes sound, it's not shot yet or anything.
- Steering is somewhat loose(comes with spare steering box), but perfectly drivable.
- Windshield is cracked(It's a Jeep thing)
- Needs new floors from the back of the front seats to the hatch(nobody's gonna fall through, there's just alot of rust)[COMPLETE OEM FLOORPAN FROM HATCH TO BACK SEATS INCLUDED]
- The roof says DDEADSERIOUS
- Some vibes, nothing serious though. Don't know where from. It can travel 70 without a problem.
- Gas gauge doesn't work(I believe the float is stuck on one of the baffles in the tank, because I tested it, and it works outside the tank.)
- No key for door locks(will include door lock cylinders that match the ignition)
- Manual locks, the power button works intermittently.
- There's an issue with the drivers side front window gear, it rolls up and down, but if it rolls past a certain point past being all the way down, you need to help it back up. Should be a simple fix, just doesn't bother me much.
- Rear doors can't be opened from the outside(can be from the inside though)
- No rockers
THE SPECS:
133,XXX Miles
Drivetrain:
- 4.0 Liter
- Raised Air Intake
- No Cat. Convertor
- Flowmaster 40 Muffler w/ Custom Tailpipe
- AW4 Transmission
- NP231 Transfer Case
- PORC SYE
- Stock Front Driveshafts F & R
Axles:
Dana 30
- 4.10 Gears
- Open Diff
- 97+ Axle Shafts
Ford 8.8
- 4.10 Gears
- Factory LSD
- Disc Brakes
- RuffStuffSpecialties Diff Cover
- Rock Krawler 3-link Long Arms
- 5.5" Rubicon Express Coils
- Rough Country Shocks Up Front
- JKS Trackbar
- JCR 1-ton Steering
- Rusty's 3.5" Rear Leafs
- Teraflex 1.5" lift shackles
- Stock shocks with position moved in rear
Tires:
- 33x12.50x15 Interco trXus M/T's
- 15x8 Steelies w/ Cragar Center Caps
Interior/Audio:
- Leather Seats(Drivers is ripped)
- 97+ Center Console
- Sound bar behind front seats
- Premier Head Unit
- Stock Tweeters
- 5.25" Pioneer Speakers
Exterior:
- TJ Rear Flares on the front
- Custom Hood Louvers
- 97+ Mirrors and Door Decals
- Lower Door 3/16" Diamond Plate
- 1/8" Rear Quarter Panel Protection
- TNT Frame Stiffeners
PARTS INCLUDED:
- 2 rear TJ flares for the rear
- Worn 33x12.50x15 trXus on brand new black steel wheel
- Sheet metal to patch some of the floors
- Tight, used steering box
- Good, used alternator
- Door lock cylinders that match the ignition
- Entire Omix-Ada replacement floor pan(from the front of the back seats to the hatch)
$3200
