Old July 13th, 2004, 11:41
mike harris mike harris is offline
vac. storage tank?
What does the little round tank(behind the front bumper on pass. side) do?Is it for heater operation or vacume disconnect for the front axle?I'm looking for one of these and every dealer I call does'nt know what I'm talking about.I tried the junk yards and every one I find is crushed.Thanks
Old July 13th, 2004, 13:46
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: vac. storage tank?
It's a vacuum bottle, and if your XJ has a disconnect front axle it operates that as well as the HVAC doors. I recall hearing something awhile back about someone using a generic or junkyard replacement, but good luck searching that.
Old July 13th, 2004, 18:33
red87cherokee red87cherokee is offline
I haven't looked lately, but JCWhitney used to sell vacuum cannisters in conjunction with their aftermarket cruise control units. They were a separate item that was available for people with small engines (I think the JCWhitney catalog specifically mentioned 3-cylinder engines ). I would think that you could adapt one of these, in a pinch.
Old July 13th, 2004, 18:58
crazyray's Avatar
crazyray crazyray is offline
I have not Confirmed, or I used a BAD email Addy
Smile Re: vac. storage tank?
any of your mid 80's on cars will have one just find one that you can fit somewhere
Old July 13th, 2004, 19:02
jneary's Avatar
jneary jneary is offline
any jeep dealer with a body shop should know what your talking about. ask for a knowledgeable parts guy and mabe refer to it as the "football"
Old July 13th, 2004, 19:53
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Any kind of sealed canister should work. I keep wondering about brazing or welding a couple of fittings onto one of those propane bottles from a hand torch or a camp stove ... or an old fire extinguisher bottle. Should be a lot more durable than the plastic ones from the factory.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
fuel tank replacement.. sidriptide OEM Tech Discussion 10 June 29th, 2004 08:42
Coolant recovery tank from a Comanche TiRod Modified Tech Discussion 2 March 11th, 2004 06:50
Gas tank leaking all of a sudden daveleau OEM Tech Discussion 9 December 21st, 2003 00:10
Power Tank Mounting DMMcG Modified Tech Discussion 1 December 8th, 2003 20:42
Gas Tank Skid lobsterdmb Wanted: Private Party Only 1 December 7th, 2003 21:05
